Go Back   OC3D Forums > [OC3D] Graphics & Displays > Overclocking
Thread Tools Display Modes
  #1
Old 11-09-17, 02:25 PM
evilcorp's Avatar
evilcorp evilcorp is offline
Member
Ryzen overclocking, v droop and llc. Crosshair hero 1700
I'm having a lot of fun with ryzen, overclocking with 1700 and crosshair hero . I have been testing stability at various settings. My 1700 can do 3.9ghz at 1.4v with ram at docp standard 3200 stable. With soc volts set to 1.15 and llc auto. I have Samsung b die and good enough cooling. I have noticed that the voltage of 1.4v is read as 1.373v in bios and under load I have seen v droop as low as 1.33v and as high, even though very briefly 1.41v. My 1700 can do 1.35v at 3.9ghz with ram at 2100mhz. I'm going to try and use the llc to stabilise v droop on the vcore. I think that my 1700 has room left to go further and I need to get the v droop under control to push for higher clocks.
Have you seen similar v droop on ryzen platform? I'm going to get the multimeter out tonight to test the actual voltage just to make sure. Does anyone know what the default llc level is set to, as a baseline?
__________________
Ryzen 1700 3.95ghz @1.37v - Still playing with 4ghz
Asus Crosshair Hero
8pack Dark pro DDR4 @3466mhz - currently testing with 3600mhz
Asus GTX 1080ti Strix OC
Cougar Panzer
  #2
Old 13-09-17, 10:11 AM
BigDaddyKong's Avatar
BigDaddyKong BigDaddyKong is offline
OC3D Elite
It's normal. Default is +0. Asus has recommended don't go over LLC 2 because of transient over volt spikes. I have went as high as 3.
__________________
AMD R7 1800X-Asus Crosshair VI Hero-16GB GSkill 3200mhz-Corsair HX850-H110i-MSI 1070-Coolermast H500-Windows 10 Pro-Dell U3011-Dell 2007FP
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
