Go Back   OC3D Forums > [OC3D] Customer Care Forums > NZXT Forum
Thread Tools Display Modes
  #1
Old 26-08-17, 11:12 AM
LookAtMeOne LookAtMeOne is offline
Newbie
Lightbulb NZXT Kraken x62 lighting issue
Hi! I just bought a Gigabyte x299 Aorus Gaming 9 motherboard. During the installation of Windows, everything was perfect and the backlight of the kraken glowed white. But after Windows was installed, backlight just does not working at all. The backlight does not react to the CAM settings in any way. And this applies only to lighting, because the cooling works fine. I've already tried everything. I reinstalled Windows 5 times, reinstalled CAM 5 times. It did not help. I have Hue+ by the way, and it works how it should. Do you have any ideas what's wrong with it, and what am I supposed to do? I'm not native English speaker. My apologies if I made a spelling mistake. Thank you!
  #2
Old 26-08-17, 12:27 PM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
Try and swap out the USB cable as they have known issues use a regular micro usb cable from say a mobile phone and plug it into the back of your motherboard and see if that fixes it if not contact NZXT tech support and they can help you further.
__________________
DRAGON'S MIST
Coolermaster H500P White ARGB=AMD Ryzen 3700X=MSI Prestige X570 Creation=Intel Optane SSD 9 480GB PCIE=32gig 3600Mhz White Dom Plats RGB= Sapphire RX5700XT Nitro Plus=Coolermaster ML360R ARGB=MSI Optix MPG341CQR=Roccat AIMO 122=Corsair Force LS 960GB=Roccat Kone AIMO White=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with RBG strip=Windows 10 Pro=Thrustmaster T16000M HOTAS=Razer Firefly RGB CE=Chasepower Pure Sinewave UPS
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
