Go Back   OC3D Forums > [OC3D] Customer Care Forums > NZXT Forum
Thread Tools Display Modes
  #1
Old 09-08-17, 04:56 AM
Excalabur50's Avatar
Excalabur50 Excalabur50 is online now
OC3D Elite
NZXT Looked After Me Awesomely
G'day All,
Just thought I'd post about my recent experience with NZXT and their tech support, and I gotta say they did AMAZINGLY Well.
So I bought a set of Aer140 RGB fans with the Hue+ and the Hue+ seemed as though it kept failing I had the first one replaced by PLE Heatherton still a no go, so NZXT sent me another Hue+ on it's own it worked for a week and a half and folded when I bought a Aer120 RGB for my 1080 Seahawk.
So NZXT said you need to smash your current Hue+ and cut all the cables in half and we'll send you a new one, so the new one arrived Monday 09/08/17 but this one also had RGB strips included which was exciting to see how they performed compared to my CableMod RGB strip and bugger me no power on the Hue+ again.
This time I really had the S***S and said I want my money back, but NZXT said it may be the USB cable and to get a hold of a micro USB cable and route it to the back of the PC instead of the internal USB header on my NZXT USB hub so I got and old Samsung S5 USB cable plugged it in and bugger me it worked.
Then I hooked up the USB strips and only 2 out of the four worked so I swapped them around and now all 4 work and OMG do they look the gonads they pulse and flash multiple colours like the fans rather than being static like my CableMod strip which has served me well as I had it since release and as far as I'm concerned my system looks amazing.
So yes I can say that NZXT's service department are really good, they try incredibly hard to get any issues that you may have sorted and that I shall use and purchase their products and recommend to others to do so and I'm bloody happy ATM.
If your own Hue+ misbehaves try the cable swap and see if it fixes it for you too.
__________________
DRAGON'S MIST
NZXT Phantom 630 White=AMD Ryzen 1700X=MSI X370 Gaming M7 ACK=Intel Optane SSD 9 480GB PCIE=32gig 3200Mhz GSkill Flare X= MSI GTX1080 Seahawk X=NZXT Kraken X62=MSI MPG341CQR=MSI GK80 Vigor=Corsair Force LS 960GB=Cougar 700M=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with Aer RGB fans and RBG strip=Pioneer BDR-209D=Windows 10 Pro=Thrustmaster T16000M HOTAS=Corsair MM800 RGB CE
  #2
Old 09-08-17, 02:59 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Logitech used to do that. Make you show a pic of your keyboard smashed, then send you a new one
Not many companies left like that now sadly. And it makes all the difference too !
__________________
"Those really high 20 series prices are just place holders"
  #3
Old 10-08-17, 12:26 AM
OC3D Elite
I must say that i was surprised when they asked my to do it as I've never had to do that before, and you are right it does make life easier.
I was talking to a mate and he said that he needed some longer screws for a Kraken G10 as the ones that came with it weren't long enough so NZXT sent him all the screws he needed so he's now got AIO's on his pair of 580's and they're still going strong
__________________
DRAGON'S MIST
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
