Go Back   OC3D Forums > [OC3D] Graphics & Displays > Overclocking
Thread Tools Display Modes
  #1
Old 27-05-17, 03:13 PM
p1987 p1987 is offline
Member
Asus 1080 08G flashing to T4 & warranty
Hello,
I am a curious if this can be achieved:
I have an Asus 1080 08G OC version and have heard that if flashing to the T4 bios, the power limits can be lifted (further than 120 ?) and achieve clocks greater than 2ghz (lottery dependent).
I have found this bios below:
https://www.techpowerup.com/vgabios/...80-8192-160803
The bios is for Asus GTX 1080 8 GB, which has lower clocks but uses the T4 bios with power limits lifted & for extreme overclocking.
I presume if I flash to this bios, I can achieve higher clocks on my O8G 1080 ? Or, have the power limits already been lifted on my card ?
Would flashing also void warranty ?
Best regards,
p1987
__________________
Ryzen 7 2700x 4.1ghz boost - Gigabyte X470 Ultra gaming Gigabyte 2080 Aorus (1940 -14900) - XFX 750w True Power PSU - 16GB Corsair 'RGB' Vengance RAM 3200mhz
  #2
Old 27-05-17, 04:12 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Yes flashing will void warranty unless you flash it back before returning it. And sometimes you can't do that because the card is dead.
Any risks involved are on you I'm afraid.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
