Go Back   OC3D Forums > [OC3D] Hardware & Software > Storage Mediums
Thread Tools Display Modes
  #1
Old 11-04-17, 11:21 AM
Merak Merak is offline
Newbie
Is my Hard Drive broken?
Hi,
lately I've been having some issues with my PC. It seemed slightly slow sometimes and two days ago I coulnd't log into my user account in windows and I got an error that some data for the profile was missing. I logged into a temporary windows account and later wiped the hard drive and completely reinstalled everything. Today, i had a bluescreen with the message "MEMORY_MANAGAMENT".
I later ran "gsmart" and it showed some errors, but I'm not sure what they mean.
I've added a screenshot to this post.
Could you give me an opinion on what this means and wether I should replace my hard drive? Apart from the issues I mentioned, everything is still working fine
Thanks in advance!
Screenshot: http://imgur.com/OO9i8uW
  #2
Old 11-04-17, 11:38 AM
Wraith's Avatar
Wraith Wraith is offline
Bettyswollocks
You think you have a faulty 2TB Seagate Barracuda, can you show us the S.M.A.R.T data for the drive? And what does the bluescreen mini dump file say (it should be on the root of drive C)?
__________________
“A person who never made a mistake never tried anything new.” ~ Albert Einstein
  #3
Old 11-04-17, 11:48 AM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Download HDtune and do a surface scan. Green = happy days red = flange.
__________________
"Those really high 20 series prices are just place holders"
  #4
Old 11-04-17, 12:06 PM
Newbie
Thanks for the quick responses!
Here is the S.M.A.R.T data: http://imgur.com/hi9ZqrA
And here is a screenshot from bluescreen viewer: http://imgur.com/JvCNSWQ
Hope this is what you meant, not sure what to make of it
Meanwhile, I'm going to scan it with HDtune
  #5
Old 11-04-17, 12:12 PM
Wraith's Avatar
Bettyswollocks
Yeah that bad boy is looking toward silicon heaven sadly. Too many bad sectors, I'd start backing stuff up and replace the drive.
EDIT: Only 13,191 Hours?! Seems very low for that drive before failures.. could you get it RMA'd.
__________________
  #6
Old 11-04-17, 12:42 PM
Reloaded2's Avatar
Reloaded2 Reloaded2 is offline
OC3D Crew
Try long formatting it using diskpart. Worth a shot
  #7
Old 11-04-17, 01:26 PM
Newbie
@Wraith
It came in the second hand PC I bought about 4 years ago on ebay, so that unfortunately isn't an option. Just out of curiosity, how long should it have ideally lasted though? Also, what could have caused it to fail this early?
@Reloaded2
I did a format when I reinstalled windows, but I assume that isn't as good as diskpart. I've never used that before, does it even work when trying to format the hard drive where windows is installed?
  #8
Old 11-04-17, 03:08 PM
Thelosouvlakia's Avatar
Thelosouvlakia Thelosouvlakia is offline
Classy-Fried-Chicken
Right, if you have a pagefile on your windows machine, turn it off completely, you don't want to stress that drive any longer, then if you want a backup I would suggest to clone the whole drive using clonezilla. It will do bit by bit clone which also stresses the drive less than copy/paste of files
__________________
Theory is when you have the "know how" but nothing works.
Practice is when everything works but no one knows why.
In our lab, theory and practice are combined: Nothing works and no one knows why
  #9
Old 11-04-17, 03:15 PM
Avet's Avatar
Avet Avet is offline
OC3D Elite
I would strongly recommend you buying a new disk. This one is on it's last breath. Formatting, and disk repair tools can prolong life a bit, but I wouldn't risk reusing it. It will die soon. Since you have fromatted it already i would assume you've backed your data so nothing important is lost. Here is your opportunity to go for SSD system drive.
  #10
Old 11-04-17, 07:22 PM
Newbie
So here are the results from HDtune by the way: http://imgur.com/a/dB9vp
Tags
bluescreen, error, failure, hard drive
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
