Go Back   OC3D Forums > [OC3D] General Forums > OC3D News
Thread Tools Display Modes
  #4021
Old 31-07-19, 04:12 PM
WYP's Avatar
WYP WYP is offline
News Guru
Originally Posted by Bartacus View Post
You can do per-CCX overclocking (or is it CCD?) with available tools. Lots of folks on OCN are experimenting with those things.
I just wish per core overclocking was possible/easy. It would be a killer feature for Ryzen, as it could fix a lot of the downsides of Ryzen overclocking.
__________________
_______________________________
Twitter - @WYP_PC
  #4022
Old 31-07-19, 04:33 PM
Bartacus Bartacus is offline
OC3D Elite
It is possible. Easy is a matter of learning, and perspective. It's easy for any geek. The big question is whether it's worth the headache or not. Is it really worth it, testing for hours to figure out which cores boost higher than others? Not to me, but YMMV. I'm content to wait for more BIOS updates. Once they get the major bugs squashed, and AGESA code is stabilized, then I'll look more into OCing and tweaking. I see no point in doing that now, other than for fun.
__________________
Guts: ThreadRipper 2950X / GB Aorus Xtreme X399 / 64GB TridentZ Royal 3600CL16 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU
Storage: 6TB RAID0 NVME array (ADATA SX8200 Pro 2TB x 3)
Water Cooling: HeatKiller TR4-Pro CPU block / HeatKiller IV GPU blocks / 360mm Darskide LP360 rads x 3 / Heatkiller reservoir
  #4023
Old 31-07-19, 04:44 PM
WYP's Avatar
WYP WYP is offline
News Guru
I know there are ways to get it to work. I'd be trying to test this right now if I had Ryzen 3rd Gen hardware here. I'm just hearing that the process is a little tedius ATM.
What I mean is that I wish it was possible via the BIOS in the same way that it's possible on Intel platforms.
__________________
Twitter - @WYP_PC
  #4024
Old 31-07-19, 04:48 PM
OC3D Elite
Ahh, understood. Yeah it's ugly right now on X570, no matter what the rabid AMD fanboys say. Patience is a virtue.
__________________
  #4025
Old 31-07-19, 05:21 PM
tgrech tgrech is offline
OC3D Elite
At least it should be easier to work out what the strong and weak cores are now if it does get simpler to do, by monitoring the per core frequencies in the chips stock config under load.
  #4026
Old 21-08-19, 02:42 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
9900KS spotted in 3DMark, Basically the 9900K but with an all core boost of 5GHz, Will apparently be made available around Q4.
https://www.guru3d.com/news-story/in...in-3dmark.html
__________________
=AMD Ryzen 9 - 3950X + PBO - XFX 5700XT Thicc III Ultra @ 2100/1800=
If you think about it, VR is free unreal estate.....
  #4027
Old 24-08-19, 01:14 PM
OC3D Elite
A particularly funky cased PlayStation 5 dev kit seems to have leaked (& confirmed by Codemasters.)
https://www.kitguru.net/gaming/matth...d-sony-patent/
Original Dutch article: https://nl.letsgodigital.org/spelcom...ion-5-console/
  #4028
Old 24-08-19, 01:19 PM
WYP's Avatar
WYP WYP is offline
News Guru
It looks to me that, like a lot of dev kits, that it is designed to be stacked on top of other dev kits for cooling purposes.
__________________
Twitter - @WYP_PC
  #4029
Old 24-08-19, 01:23 PM
OC3D Elite
Yeah it does seem to have little recesses so they slot in nicely, I guess the increased surface area for the vents is probably necessary for this one can be so small compared to previous devkits (Edit: Actually it's not that small going from that disk drive size I guess it's just a monster chip or two hiding in there)
  #4030
Old 29-08-19, 05:38 PM
Dicehunter's Avatar
Resident Newb
So Crytek just teased their new Cryengine update 5.6 and at 2:21 in the trailer the original Crysis 1 music starts playing, It shows Crysis 1 like terrain and it ends with a shot of the infamous beach scene, Now either they're going to release a remastered version of Crysis 1, Crysis 4 is going to be a thing or it's just a nod to Crysis 1 fans, I'm personally hoping it's either a remaster or Crysis 4.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
