Thread Tools Display Modes
  #11
Old 02-04-12, 10:12 PM
DIGITALI5 DIGITALI5 is offline
Newbie
How easy would it be to t
  #12
Old 02-04-12, 10:13 PM
Newbie
How easy would it be to tOtally bugger the CPU though? Thinking about risking it with my 2600k but it probably won't make a massive difference seeing as the coolers only a h70!
  #13
Old 16-12-12, 04:59 AM
Mix Mix is offline
Newbie
Is this going to help new CPU like say a £450 3930K straight out the box.
Also see above post
  #14
Old 10-06-13, 04:29 AM
233Kosta's Avatar
233Kosta 233Kosta is offline
Member
I'd try with some gallium based thermal grease first (make sure you don't use aluminium with it, it will dissolve it). Phobya Liquid Metal comes to mind, but there are other great options out there too, some - probably better.
In any case, see how hot it gets first.
__________________
24/7
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
