Originally Posted by zan76
Cheers King might try them but its the same for prime and aida64
what are the normal temps for 6600k at 1.25v as i said mine are about 20 on idle but only go up to about 40 doing the tests
I don't see that as being terribly abnormal? You could have won the chip lotto haha! What cooling are you using? Are the fans blasting when you are under load?
EDIT: You are only .05v above normal. And looking at your normal temps I don't see anything too abnormal as I stated. If you are really concerned run the test for about 30 min to an hour.
