Go Back   OC3D Forums > [OC3D] Cooling Forum > Liquid Cooling
Thread Tools Display Modes
  #1
Old 11-01-19, 09:41 AM
Dawelio's Avatar
Dawelio Dawelio is offline
OC3D Elite
AIO tips/recommendations?
Heya everyone,
Was just wondering if anyon in here perhaps know any 240mm AIO's that has a bit shorter and more flexible tubing than for example the Corsair H100 v2 and the ASUS ROG RYUO? Since the latter has a bit thinner and way more flexible tubing than the former mentioned, although they are very long.
Trying to find one that with the most ease, will go inside an NCASE M1.
Thanks,
Dawelio
  #2
Old 11-01-19, 11:52 AM
tinytomlogan's Avatar
The Guvnor
They are all roughly the same length sadly dude. If you want a shorter length youd have to buy an AIO you can take apart and cut the hoses, that would mean refilling and bleeding though so youre at the point of just watercooling tbh.
Alphacool do some good AIO options (poump in the waterblock) you could strip and make the hoses the right length
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
