Go Back   OC3D Forums > [OC3D] Graphics & Displays > Graphics Cards
Thread Tools Display Modes
  #1
Old 29-04-11, 06:12 AM
KING_OF_SAND KING_OF_SAND is offline
OC3D Elite
So my SECOND 6990 came in today after returning my Sapphire 6990 for making a buzzing/squealing sound.
This only happens in 3D applications and during the 3D application the buzzing intensifies depending on how much is going on in the game (it is directly correlated to how much GPU usage there is, the lower the usage the less noise, and so on). The more going on the higher pitch and louder the noise.
This also happens when my FPS goes above 40FPS in some apps, and in other it is 60FPS. If i enable Vsink in my most of my 3D apps the buzzing stops.
Sense this is my second 6990 with the same problem i am becoming more convinced that it is not the card itself rather the PSU. Let me remind you, the buzzing IS coming from the GPU. From what i have been reading some either older PSUs or week PSUs can make a GPU (or other computer component) make noises due to lack of power coming from the PSU.
Is this true?
My PSU is a BFG1000w so it would fall under the category of "old."
Could my PSU be the reason for my 6990 buzzing?
PS: i wont be able to test if it is my PSU until tomorrow.
  #2
Old 29-04-11, 06:59 AM
S_I_N's Avatar
S_I_N S_I_N is offline
OC3D Elite
might be the output cable to the monitor as well since when you enable vsync it goes away why not leave vsync on???? it doesnt hamper performance from what i know. it just syncs the vc to ur monitors capability.
__________________
Intel 7700K
Aorus Z270 Gaming K7
2x8GB GSKILL Trident Z 3200MHz
Intel SSD6 256Gb x2 in Raid 0
Samsung 850 EVO 1TB
EVGA GTX1080 FTW2 iCX Heat Killer IV block
Custom water Cooled Hardware Labs GTS360/240
ThermalTake Grand RGB 1000w PSU
Corsair Crystal 570X
  #3
Old 29-04-11, 07:01 AM
OC3D Elite
I have already tried all the outputs on the card, and the same thing happens. Also some games with vsync on, it makes the mouse lag.
  #4
Old 29-04-11, 10:19 AM
GuyIncognito GuyIncognito is offline
Member
I'm not an electrical engineer, but from what I've read on forums, an inductor can make noise. Maybe, it's just poor design.
  #5
Old 29-04-11, 10:32 AM
tinytomlogan's Avatar
The Guvnor
If its doing it under load then........................... thats normal. Try watching the video review I made
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #6
Old 29-04-11, 12:27 PM
Ya93sin's Avatar
Ya93sin Ya93sin is offline
OC3D Elite
Have you got a second Sapphire one or did you get a different brand this time?
And the noise is completely normal, its probably the most offputting thing about the card, and probably the reason why many went for the 590.
  #7
Old 29-04-11, 03:04 PM
OC3D Elite
i did see your review, but i do not recall you saying anything about a buzzing sound?
  #8
OC3D Elite
I went with diamond.
  #9
Old 29-04-11, 03:09 PM
The Guvnor
IN the video it clearly showed the insane ammount of noise from the card. It was one of my main reasons for prefering the 590.
__________________
  #10
Old 29-04-11, 03:14 PM
OC3D Elite
I thought that was just the fan you were referring too. I am watching it again anyways I am not coherent right now, its 7am.
At least my diamond 6990 is a hell of a lot quieter than my sapphire one. my sapphire was making a REALLY loud squealing that was even louder than the fan at 100%. also i have a video you can see were i recorded the clicking.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
