Go Back   OC3D Forums > [OC3D] General Forums > OC3D News
Thread Tools Display Modes
  #1
Old 20-09-19, 09:05 AM
WYP's Avatar
WYP WYP is offline
News Guru
AMD's Ryzen 5 3500X Leaks - Low-cost Ryzen for budget gamers
The ideal CPU for the £150ish gaming CPU market?
Read more about AMD's leaked Ryzen 5 3500X processor.
__________________
_______________________________
Twitter - @WYP_PC
  #2
Old 20-09-19, 09:27 AM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Wicked. I'll probably upgrade my 10 core rig with this. I want higher clock speed for 1080p.
__________________
  #3
Old 20-09-19, 06:14 PM
Linchpin Linchpin is offline
Newbie
Thinking overclocking will give it a boost seems like a stretch given how the rest of Ryzen 3000 series is effectively non-overclockable. Given that AMD generally relies on higher speed RAM as well they better nail the pricing of this thing just right and undercut the 9400f by a healthy amount.
  #4
Old 20-09-19, 07:42 PM
Zoot's Avatar
Zoot Zoot is offline
OC3D Elite
AMD is really hitting Intel hard in the mid range. There really isn't much point to getting an i5 anymore with the R5 3600 around, this will just add that.
__________________
Desktop: AMD Ryzen 7 3700X | X570i Aorus | 32GB Corsair DDR4-3200MHz | RX 5700 XT | Aorus PCIe 4.0 1TB M.2 | Fractal Define Nano S
Home Server: AMD Ryzen 3 2200G | Asus Prime B450M-A | 16GB Crucial DDR4-2400MHz | 39TB | Fractal Design Define R5
HTPC: AMD Athlon 5350 | ASRock AM1H-ITX | 4GB Corsair DDR3-1333MHz | MiniBox M350
  #5
Old 20-09-19, 07:49 PM
AMD Enthusiast
If you aren't aiming for 240fps at 1080p then there isn't all much point in getting Intel these days. Zen 2 can hit 144+ easy and consistently.
AMD has just made solid CPU's that force's users to spend top dollar for the best pure performance and many people aren't willing to do that for what Intel charges. AMD hit the perfect spot. So I'm in agreement with Zoot here, adding this just adds on top of their placement atm.
__________________
I am Iron Man.
  #6
Old 21-09-19, 09:07 PM
Nine Iron Nine Iron is offline
Member
I got my 3600 for £159 off eBay.
New .
__________________
Ryzen 5 3600
Asus B450-F Strix Gaming
16GB Corsair DDR4-3600
Gainward 1070
Samsung SM961 256GB, Intel 660P 2TB
LG BH16NS40 BD-RE
Corsair RM650x
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
