Go Back   OC3D Forums > [OC3D] Hardware & Software > Software Section
Thread Tools Display Modes
  #11
Old 17-09-19, 08:21 PM
AMD Enthusiast
Try rolling back the BIOS or try a different newer version than your previous if you want a newer one. Though I would stick with what you know works first.
__________________
I am Iron Man.
  #12
Old 18-09-19, 01:03 AM
ScottytooHotty ScottytooHotty is offline
Newbie
Ok so I re-installed Windows on my PC and that didn't change anything, and annoyingly after that remembered I had a old spare graphics card (R9 270X) so I put that in and the issue is no longer present.
I am going to take my 1080 to a friends to test it in their PC tomorrow.
__________________
Current Setup: Phanteks Enthoo Pro M Window Edition - i7 8700K 4.7ghz - ASUS ROG Strix Z-370 H gaming mother board - NZXT Kraken x72 AIO - 16gb Corsair Vengence RGB 3000mhz - Asus Strix GTX1080 - 500gb 970 EVO M.2 - 250gb Sandisk M.2 - 250gb 850 EVO - 120gb Samsung 840 - 60GB OCZ Vertex - 1TB Seagate Barracuda - Corsair RM850x - Asus PG279 27" 165hz - Iiyama 27" 120hz - Corsair Harpoon mouse - Corsair K70 RGB Keyboard - Logitech Z-5500 speakers - Blue Snowball mic.
  #13
Old 18-09-19, 07:18 AM
Warchild Warchild is online now
OC3D Elite
Have you been playing for the firmware of the GPU?
  #14
Old 18-09-19, 10:50 AM
Newbie
No I have not.. I’m not sure what might have caused it.
  #15
Old 18-09-19, 11:41 AM
tgrech tgrech is offline
OC3D Elite
I had this exact issue when my PSU started to go off, changed GPU and it was fixed, but it was not to do with either GPU, rather because that GPU swapped in was lower end with lower power draw and didn't strain the PSU as much, it's not massively likely this is the issue but to be safe I'd still check the voltages reported from the motherboard(Check if they're low of varying heavily particularly with load), can usually find quite quickly in your mobos software or bios, as the GTX1080 is indeed a higher draw GPU than that RX270 under load.
  #16
Old 19-09-19, 01:09 AM
Newbie
Ok, So as far as I can tell all voltages seem to be fine, temps are fine, the only thing I can see wrong is that the cpu inconstantly at 4.4 ghz instead of dropping at all when idleing, and my gpu clocl is idleing at 1.1ghz and the memory clock is stuck at 10ghz.
__________________
  #17
Old 20-09-19, 01:10 AM
Newbie
Ok So I just tried the card in the other pci express port and it seems to be working flawlwssly now.. although my CPU clock is still constantly maxed and the gpu is idleing at 1.1ghz.
__________________
  #18
Old 20-09-19, 07:14 AM
RobM's Avatar
RobM RobM is offline
OC3D Elite
you have another PSU to test with?
__________________
ASUS Prime x370 Pro | Ryzen 5 1600 | Antec 240 AIO | Corsair Vengance RGB 3000 2 x 8Gb | Asus Strix RX 470 | Samsung Evo 120gb ssd | Seagate Baracuda 1tb storage | EVGA 500w | Phanteks Entho ProM Acrylic Window | Windows 10 and Linux Manjaro
  #19
Old 20-09-19, 03:08 PM
Newbie
If it was PSU would the graphics card work ok in the second pcie slot and not the first?
  #20
Old 20-09-19, 03:33 PM
RobM's Avatar
OC3D Elite
probably not, but I would at least rule it out given your CPU is still acting up.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
