Go Back   OC3D Forums > [OC3D] Processors & Platforms > Mainboard & CPU
Thread Tools Display Modes
  #1
Old 30-08-19, 03:54 PM
tolagarf's Avatar
tolagarf tolagarf is offline
OC3D Crew
ASRock Fatal1ty X470 Gaming-ITX/ac VRM temps?
Hey there.
I hope someone might know an answer to this, on how to read VRM temps on the ASRock Fatal1ty X470 Gaming-ITX/ac motherboard, as I've had 3-4 sudden hard reboots with this PC over the cause of 3-4 months. So yeah it's not often and it's been both in gaming and doing web browsing, normal workloads as well.
I suspect either the motherboard or PSU causing the problem, however my PSU tester goes into a constant beep with the PSU even though the display shows no errors. This is the second PSU I've had of this kind and it seems they all do it. I noticed some very high temps in HwInfo32 under the two AUXTIN which you can see for yourself here:
So I'm really unsure if those two are the VRM temps, or if it's actually hidden.
PC Specs:
ASRock Fatal1ty X470 Gaming-ITX/ac @ BIOS 3.40
AMD Ryzen 2600X CPU @ stock
G.Skill DDR4 2x8 GB 3200 MHz CL14 RAM
Corsair SF600 V2 PSU
EVGA GTX 1080 Ti SC2 Gaming graphics card
Noctua NH-U14S CPU cooler
3 x Noctua NF-A12x25 PWM fans
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
