Go Back   OC3D Forums > [OC3D] Customer Care Forums > Asus UK Customer Care Forums
Thread Tools Display Modes
  #21
Old 01-09-19, 07:54 AM
b33rd0g b33rd0g is offline
Newbie
Originally Posted by hmmblah View Post
The mini-dtx board? Where’d you get that?
yes the mini-dtx
it was pretty much the only one in stock that was of a suitable size for my case in my country, which is norway. got it at proshop.no
  #22
Old 01-09-19, 03:46 PM
hmmblah's Avatar
hmmblah hmmblah is offline
Moderator
Originally Posted by b33rd0g View Post
yes the mini-dtx
Lucky! It's not out in the US yet. What do you think of it so far?
__________________
CaseLabs Mercury S3 | AMD 3900X | ROG CH8 Impact | RTX 2080 Super | 16GB DDR4 | 1TB NVMe
Acer Predator Z35P
  #23
Old 01-09-19, 04:10 PM
Dawelio's Avatar
Dawelio Dawelio is offline
OC3D Elite
Bit off topic here, but may I ask what you think of your own 2080 Super and if you may have experienced any sound related issues while using it?...
  #24
Old 01-09-19, 05:47 PM
Newbie
yeah i think it more or less came straight from factory because the pre installed bios was just 2 weeks old or so.
as for what i think of it, im not a hardcore overclocker or anything, the only thing i did was to up the ram speed to 3200, switch off some LEDs and minor things, so i cant say much about that. i left the cpu stuff as it was.but it works, is silent and seems to stay cool. not sure what to think of that so-dimm thing or what its called, that sticks out like a tongue. if i didnt stick 2 small rubber pads on the bottom of it it would rest on the gpu backplate. it looks odd. not sure its a design that will stay. but the m.2 (thats installed on the so-dimm, and is not one of those hyperfast new ones) works and was 30C the one time i checked.
the 3800x seems to peak at around 4.5 ghz one core, all cores are running at 4.25-4.3 ghz when stressing all cores
  #25
Old 01-09-19, 07:33 PM
Newbie
btw which temp is the correct cpu temp? i guess 2 is out and 1 is the one that looks most like my old 2700x, BUT, cpu fan speed and cpu fan noise indicates number 4 is correct, its all more silent than the 2700x, even though ive set the aio fans identically. these are tremps from a short death of the outsider session
  #26
Old 01-09-19, 08:29 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
I always go by the hottest, which is usually CPUTIN or something.
__________________
  #27
Old 01-09-19, 09:10 PM
hmmblah's Avatar
Moderator
It's surprisingly smaller than my 1080 FTW, but it's loud. Hopefully I'll have it under water before too long. I haven't experienced any sound issues and I use the onboard sound from the motherboard.
The board will sit horizontal in my case I shouldn't have to worry about the so-dimm card being obvious. My only concern is if it will interfere with water cooling the GPU and clearance on the rad in the roof of my case. I haven't measured anything yet. I did purchase the Gigabyte PCIe 4 m.2 so hopefully temps won't be too bad. I'd assume they would have done some testing with that...hopefully...
__________________
Acer Predator Z35P
  #28
Old 02-09-19, 07:38 AM
Newbie
is that the copper coloured arous one? is the idea to remove the heatsink from the m2, im not sure it will fit inside the so-dimm. or ditch the so-dimm lid, which i guess is also a heatsink ?
edit: added a photo that shows the so-dimm
  #29
Old 02-09-19, 02:51 PM
hmmblah's Avatar
Moderator
Yeah that’s the one. I’ll probably remove the heatsink from the m.2 drive. That so dimm card is way smaller than I was expecting.
__________________
Acer Predator Z35P
  #30
Old 02-09-19, 03:02 PM
Newbie
its the msi 2070 armour thats huge
Tags
2700x, 3800x, x470
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
