Go Back   OC3D Forums > [OC3D] Processors & Platforms > Mainboard & CPU
Thread Tools Display Modes
  #11
Old 02-09-19, 03:34 PM
Bartacus Bartacus is offline
OC3D Elite
Level 1 techs has a great thread regarding BIOS settings for the Master. Well worth a read:
https://forum.level1techs.com/t/aoru...ings/145081/65
__________________
Guts: Ryzen 3900X / GB Aorus Master / 16GB TridentZ 3600CL15 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU / Case Labs M8
Storage: Corsair Force MP600 1TB NVME / 6TB RAID0 HDD array / 4TB RAID0 SSD array
Water Cooling: Watercool HeatKiller IV blocks on CPU & GPUs / 4 360 rads + 240 rad / Heatkiller reservoir / dual D5 pumps
  #12
Old 02-09-19, 03:41 PM
tinytomlogan's Avatar
The Guvnor
There is a few ready to go live boys but the VRM thing held them up a bit (I wanted to have that covered first so that I can draw attention to it for certain boards)
Taichi wont be getting done though and tbh the BIOS is always the bit that ruins them. Gigabyte have epic boards this generation and only have some bios bugs against them when comparing to Asus.
Anything else is normally put at the door of AMD because they create a lot of the code (AGESA) that goes into the BIOS. Its complicated to try and explain whats AMD and whats Vendors tbh.
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
