Thread Tools Display Modes
  #21
Old 06-08-19, 09:57 AM
Warchild Warchild is offline
OC3D Elite
Originally Posted by NeverBackDown View Post
I'm 99% sure you can still get a free Windows key by upgrading from 7 to 10. I have done it 3 times now, although about a year ago ago, but still far after the free upgrade expired.
Just use the media creation tool from MS and upgrade through that to do it.
Just make a copy of your window 7 disk and then when upgrading it should work out and if not you can always roll back.
I believe they stopped that. But you can buy keys for around £20 which is still a good deal to me. Once you registered last year, it was ok. I don't think it works for new users though.
Guru3D had a link not so long ago promoting it.
  #22
Old 06-08-19, 10:42 AM
tgrech tgrech is offline
OC3D Elite
Yeah though also if you "forget" to put in a key code for a while when looking at your options, Windows 10 does absolutely nothing to stop you from using it anyway(Indefinitely), you just can't change your theme and stuff and get a little watermark after several months I think. One of my friends has been using Windows10 for like 3 years without putting a code in or having a license(Or using any nefarious tools).
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
