Go Back   OC3D Forums > [OC3D] Graphics & Displays > Graphics Cards
Thread Tools Display Modes
  #1
Old 23-07-19, 04:56 PM
p1987 p1987 is offline
Member
Flashing standard RTX to Super
Hi,
I wonder if in theory you could flash an RTX 2080 to RTX 2080 super ?
This is suppose could work for the 2060 & 70 models too ?
What has Nvidia been like in previous generation restriction ?
  #2
Old 23-07-19, 05:03 PM
AMD Enthusiast
It would be impossible for you to flash a 2070 to a 2070 super since they are using completely different dies. So not sure where this logic is coming from and your source is probably just trolling you.
As for the 2060 flashing I highly doubt Nvidia would let you. They are smarter than that and 99% likely lasered out the faulty dies.
__________________
I am Iron Man.
  #3
Old 23-07-19, 05:17 PM
Member
Hi,
I wouldn't say it was logic or being trolled - curiosity if anything .
I see. In this case if they are using a different die then it would be impossible.
Would be great if it was possible - would give their original buyers a nice little boost and not make them feel as if they arn't being left out.
__________________
Ryzen 7 2700x 4.1ghz boost - Gigabyte X470 Ultra gaming Gigabyte 2080 Aorus (1940 -14900) - XFX 750w True Power PSU - 16GB Corsair 'RGB' Vengance RAM 3200mhz
  #4
Old 23-07-19, 05:18 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Originally Posted by p1987 View Post
Hi,
You're being left out. You can trust me.
__________________
"Those really high 20 series prices are just place holders"
  #5
Old 23-07-19, 06:05 PM
RobM's Avatar
RobM RobM is offline
OC3D Elite
You might be able to flash 2070 super to a 2080 (same die)
__________________
ASUS Prime x370 Pro | Ryzen 5 1600 | Antec 240 AIO | Corsair Vengance RGB 3000 2 x 8Gb | Asus Strix RX 470 | Samsung Evo 120gb ssd | Seagate Baracuda 1tb storage | EVGA 500w | Phanteks Entho ProM Acrylic Window | Windows 10 and Linux Manjaro
  #6
Old 23-07-19, 06:21 PM
WYP's Avatar
WYP WYP is offline
News Guru
No Nvidia graphics cards come to mind when I think of GPU "unlocking". It's typically something that only worked with AMD kit.
__________________
_______________________________
Twitter - @WYP_PC
  #7
Old 23-07-19, 07:07 PM
tgrech tgrech is online now
OC3D Elite
Yeah NVidia usually fuses off their cores(Physically destroys the connections in silicon essentially), AMD usually do too but for low cost chips AMD often save money by just disabling them in the BIOS. Generally, if cores are disabled(Fused or not) it's because most of the silicon made for that SKU has non-functional cores and they didn't consider it worthwhile making a separate SKU for the dies with full functionality, so even then it's just pot luck whether an "unlock" would work.
Of course, NVidia has used the same TU106 die for the RTX2060, RTX2060S and RTX2070 now, the differences lie purely in what they fuse off[Though for the OG-2060 the fusing off of some of the memory bus also meant some PCB/memory changes], so from a market perspective they can't really leave the possibility open for unlocking.
  #8
Old 23-07-19, 07:09 PM
AlienALX's Avatar
OC3D Elite
GTX 465 to 470 though they soon put a stop to that and the FX5900 - 5950u come to mind.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
