Thread Tools Display Modes
  #11
Old 12-07-19, 11:12 PM
AMD Enthusiast
got more streaming information for you if it helps!
__________________
I am Iron Man.
  #12
Old 12-07-19, 11:33 PM
WillSK's Avatar
WillSK WillSK is offline
OC3D Elite
Send a message via Skype™ to WillSK
Nice one dude!
__________________
My Rig : Fractal S2 Case, ASUS Crosshair VIII Hero, Ryzen 3800X, Corsair H115i Platinum, MSI GeForce RTX 2080 GAMING X TRIO, 32 Gb Team Pro Dark RAM 3200Mhz, Samsung 970 EVO SSD, Samsung 850 Pro 500GB SSD, Seasonic Prime Ultra Titanium
  #13
Old 13-07-19, 03:07 AM
AMD Enthusiast
Originally Posted by WillSK View Post
Nice one dude!
Took me a while to find this thread, spent 10 minutes looking for it. Thought of this thread immediately once I found the video
Hope it helps!
__________________
I am Iron Man.
  #14
Old 13-07-19, 11:23 AM
WillSK's Avatar
OC3D Elite
Hope it helps!
It's weird, everything is telling me to go 9900k. I'm a gamer primarily and the fact is that at the moment the 9900k performs better.
However part of my brain keeps being like AM4 is about for another gen (maybe 2?) Intel will almost definitely introduce a new socket (again) and I just don't want to support the practise.
Streaming for me is just a potential side thought rather than something i'm committed to going big on so not the deciding factor.
Maybe I'll wait a couple of months and see how ryzen 3 matures. Plus reduced prices won't hurt.
__________________
  #15
Old 13-07-19, 01:41 PM
cooperman's Avatar
cooperman cooperman is offline
OC3D Crew
__________________
i5 4690-Gigabyte Z97P-D3-16Gbs 1866Mhz Kinston HyperX Fury Black-Asus GTX 980 Corsair h80i-sandisk 256gb ultra plus-250gb Intel SSD-WD Blue 500gb-Seasonic M12-620w-Cooler master haf xb.
  #16
Dark NighT's Avatar
Dark NighT Dark NighT is offline
OC3D Elite
I'd go Amd purely for the fact it doesn't suffer as much with security issues which keep dragging down intel performance with updates, and if it's only a tad bit slower then yeah, no brainer really.
  #17
Old 13-07-19, 02:27 PM
WillSK's Avatar
OC3D Elite
Originally Posted by cooperman View Post
Yeah I did see this!
defo some points deducted from the 9900k here
I agree to be fair, most likely gonna go the Ryzen route
__________________
  #18
Old 13-07-19, 03:30 PM
tgrech tgrech is online now
OC3D Elite
Yeah the benefits are that you generally get so close in max performance that you probably wouldn't notice the gap but have a fair bit of power "spare" to maintain that performance regardless of what other stuff your PC is doing, and that Zen3 will probably close the gap further with what will likely still be Skylake 14nm derived competition at that point.
  #19
Old 13-07-19, 04:15 PM
AMD Enthusiast
Nobody should realistically be using X264 Slow so I don't think that's really a great point you gave. It's quality improvement is almost non existent.
Not sure if you watched the videos but if you are serious about streaming and want to do it more, Ryzen provides a better stream for the viewers where Intel provides a better gaming experience. Ryzen is a few percent slower than Intel for the gamer but far better for the viewers.
So really it's just Ryzen if you plan on doing 1080p60.
If you aren't going to use a webcam then use NVENC. It's the best solution. Using a webcam it gets overloaded and performs worse for the viewers.
__________________
I am Iron Man.
  #20
Old 13-07-19, 04:41 PM
looz's Avatar
looz looz is offline
OC3D Elite
NVENC getting overloaded makes literally no sense, OBS will merge the two video streams and only after that it gets encoded. It's absolutely fine to use NVENC with a webcam.
Shadowplay might work differently, but it's useless for streaming.
__________________
i7 8700k - 16GB - 2060 FE - 512GB 970 & 850 EVO - AKG K702
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
