Go Back   OC3D Forums > [OC3D] Hardware & Software > Software Section
Thread Tools Display Modes
  #1
Old 24-06-19, 03:08 PM
SebastianAltena's Avatar
SebastianAltena SebastianAltena is offline
Newbie
4770k win7 vs win10 gaming performance
I'm running win7 with intel 4770k, would directx 12 improve performance even with all of the security fixes for older intel CPUs that hamper performance?
  #2
Old 24-06-19, 03:26 PM
tgrech tgrech is offline
OC3D Elite
Depends on which game and with which GPU, but it definitely won't be a performance regression, Win7 has had more or less all of Win10's security patches backported to it, uses all of Win10's telemetry & other security systems since the latter's launch. Then Win10 has reduced RAM usage and better resource management amongst other things.
  #3
Old 24-06-19, 05:49 PM
Avet's Avatar
Avet Avet is offline
OC3D Elite
That depends on the game. But you will have much better overall experience. Win10 has much less overhead than Win7.
  #4
Old 24-06-19, 06:15 PM
Newbie
I have disabled auto updates and rolled back after it has started nagging me to install win10, so no security patches are installed.
I'll buy new (used) gpu soon, nVidia 1070 or 1080.
  #5
Old 24-06-19, 06:25 PM
Avet's Avatar
OC3D Elite
You should never do that. No matter how irritating, Windows updates are actually very important.
  #6
Old 24-06-19, 06:39 PM
Newbie
Yeah yeah, I know, but I use that machine only for gaming.
  #7
Old 24-06-19, 06:49 PM
Avet's Avatar
OC3D Elite
Exactly my point. That machine has all of your email, gaming accounts, and credit card information. It is a gold mine.
  #8
Old 24-06-19, 09:08 PM
Newbie
Only account that machine has is steam and I use 2 factor, it doesn't even have my GOG account, let alone credit cards or email. so don't worry about it.
  #9
Old 24-06-19, 09:14 PM
Newbie
BTW does anyone know why I'm not getting notifications even though I'm subscribed to this thread?
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
