Go Back   OC3D Forums > [OC3D] Graphics & Displays > Graphics Cards
Thread Tools Display Modes
  #1
Old 23-05-19, 09:21 AM
tiribomba tiribomba is offline
Newbie
upgrade 2080ti or 9900k+z390+32gb ram
so long story short I can upgrade my PC but I am able to purchase only one option its either the gpu or the cpu mobo ram combo if I will get the 2080ti it will go with x58 with w3690 4.4ghz and 12 gb ram and if i will get the i9 combo it will go with my curent r9 290x what to do what to do
  #2
Old 23-05-19, 10:26 AM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
What do you do with your PC? if it was me I'd split the difference and I'd get an AMD 2600 with a B450 Tomahawk 16G Gskill [email protected] and a 2080 or even 2070 depending on what resolution you game at assuming you're a gamer of course and then you don't need to worry about any of the newer and older attacks that affect Intel and you still get a great system that will be great at 1440p - mid spec 4K, and if you wait just a little bit the newer AMD chips launch in July and will be announced on the 27th May 2019
__________________
DRAGON'S MIST
NZXT Phantom 630 White=AMD Ryzen 1700X=MSI X370 Gaming M7 ACK=Intel Optane SSD 9 480GB PCIE=32gig 3200Mhz GSkill Flare X= MSI GTX1080 Seahawk X=NZXT Kraken X62=MSI MPG341CQR=MSI GK80 Vigor=Corsair Force LS 960GB=Cougar 700M=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with Aer RGB fans and RBG strip=Pioneer BDR-209D=Windows 10 Pro=Thrustmaster T16000M HOTAS=Corsair MM800 RGB CE
  #3
Old 23-05-19, 10:29 AM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
You literally took the words straight out of my mouth.
__________________
"Those really high 20 series prices are just place holders"
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
