Thread Tools Display Modes
  #21
Old 13-09-19, 08:24 AM
SaaintJimmy SaaintJimmy is offline
Member
Originally Posted by Wraith View Post
Truely Incredible! This stopped being a generic mod ages ago it's simply a work of art now. Kudos.
Thank you so much! I love when my work gets labeled as work of art because that's exactly what I aim to!
__________________
Facebook page: Explore Modding
Youtube channel: Explore Modding
  #22
Old 13-09-19, 08:31 AM
Member
A quick look at the first tubing mock-up. I thought I would do something less intricate with the loop this time but I just can't help it, I love parallel runs
Made the bracket for the PSU mounting in the top section
I reshaped the two back panels with this characteristic cut I'm bringing along this whole project, to make it smoother and more geometric
Also began working on the front and top panels cutouts, I made this simple design in Silhouette Studio, cut the stencil and went over it with a pen once I applied it to the panel, this way all the sections in both panels will be exactly the same. It would've been hard doing it by hand since they're very irregular shapes. Obviously cut with my trusty scrollsaw
And as anticipated in the previous post, I swapped the red LEDs of the lightbox with WRGB strips
__________________
  #23
Old 13-09-19, 01:50 PM
Wraith's Avatar
Wraith Wraith is offline
Bettyswollocks
There's a lot to be said for parallel tubed loops, I personally love them over intricate complex bends, plus given the nature of your build with the sharp angles and edges straight pipes would compliment it way more over curves. Keep it up man this is fast becoming my all time drool worthy build log.
__________________
“A person who never made a mistake never tried anything new.” ~ Albert Einstein
  #24
Old 18-09-19, 08:24 AM
Member
Same treatment for the top panel, again cut with a scrollsaw
And now something pretty unique. Aside from the resin panels, the new technique I couldn't wait to try out for this project was... growing crystals! And what better fitting project than a Realgar project?
What I did was forming a shape in polymer clay, let it dry, then coating it with glue and lay some borax on the surface, so that it could cover it and stay there once the glue dried.
Then I boiled some water and created a saturated solution with borax, adding it until it couldn't dilute anymore. I put the piece in the solution, waited over night and here you go: a nice big geode!
Unfortunately, I tried to dye the solution with red, because I wanted the crystals to be red, but it turned out I had to add sooo much dye in order to obtain a crystal that was red enough. In fact, what I got was more like a pink salt colour
Ready to take on another try (that would've meant buying gallons of dye), I thought YOLO and tried to paint the crystal with a metallic red, which is also a bit translucent, so maybe I wouldn't have lost most of shine from the crystals. And it turned out awesome, even better than I could've imagined!
This is what it was made for
Still for the front panel, I had to make something to fill the other cutouts I made. So I cut a pair of acrylic panels, turned them into a frame and taped the bottom with aluminum tape. It was time for another epoxy pour!
__________________
  #25
Old 18-09-19, 09:01 AM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
WOW dude that's freakin amazing what you did to get that crystal......just WOW!
__________________
DRAGON'S MIST
NZXT Phantom 630 White=AMD Ryzen 1700X=MSI X370 Gaming M7 ACK=Intel Optane SSD 9 480GB PCIE=32gig 3200Mhz GSkill Flare X= MSI GTX1080 Seahawk X=NZXT Kraken X62=MSI MPG341CQR=MSI GK80 Vigor=Corsair Force LS 960GB=Cougar 700M=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with Aer RGB fans and RBG strip=Pioneer BDR-209D=Windows 10 Pro=Thrustmaster T16000M HOTAS=Corsair MM800 RGB CE
  #26
Old 18-09-19, 10:01 PM
Bartacus Bartacus is offline
OC3D Elite
DAMN son! I think this is the first time I've seen a resin pour used in a PC build, and it looks SPECTACULAR!!! Plus that crystal is an awesome detail. What a combo!!!
__________________
Guts: Ryzen 3900X / GB Aorus Master / 16GB TridentZ 3600CL15 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU / Case Labs M8
Storage: Corsair Force MP600 1TB NVME / 6TB RAID0 HDD array / 4TB RAID0 SSD array
Water Cooling: Watercool HeatKiller IV blocks on CPU & GPUs / 4 360 rads + 240 rad / Heatkiller reservoir / dual D5 pumps
  #27
Old 19-09-19, 08:23 AM
Member
Finally got started with the paintjob! I had a very specific idea for this: balancing a stone colour/effect with shiny red details that resembled the minerals inside the stone. For that purpose, I chose two colours for the stone, an avory white and a golden grey, and helped myself with two different stone effects from Rustoleum. They're simply clear coats with chunks of paint in it, that will simulate a stone-ish look after having dried.
I started with the main frame of the chassis, giving it the golden grey
Then I moved on to the two panels from the lightbox, as well as the two back panels (how cool to they look when clear? ). This time I went with the avory white
And the internal top and bottom panels are done as well
I also gave a stone look to the radiator, and now it's a true monolith with crystal fins! Some will have doubts about painting the fins, but to be honest, for what I want to achieve with this project, I won't need those 2-3 degrees, but I really needed to get rid of most of the black in the build
It's external panels' turn now. I mainly used avory white for these, except for the plastic part of the front panel, for which I used the golden grey
__________________
  #28
Old 19-09-19, 08:24 AM
Member
Thanks for the amazing support guys! I always get the most amazing feedback on this forum
__________________
  #29
Old 20-09-19, 10:35 AM
Member
Time for another batch of crystals, this time for the front piece that used to have I/O ports on it. I cut everything that was visible when mounted, and filled the void with pipe cleaners, so that when the piece gets dipped in the borax solution, crystals will grow on them.
I had to adjust the crystals a bit with a file because they grew too much in some area and the two panels wouldn't fit
Since the shape of the pipe cleaners was still a bit too visible, and I wanted some bigger crystal, I grabbed some of the single crystals left from the first batch, and super glued them on the new geode
The painted and the result was beautiful imho!
Then I went to finally put the front panel together! This whole panel took a whole lot of work and different techniques applied, but I think it was well worth it.
Also painted the top mesh, after having stripped the black paint off it, so that when going over with the metallic red, which is slightly translucent, some of the shine from the metal would pop up
Bonus pic: I finally finished polishing the resin panel. Man it does take quite a lot of work to get a nice result!
__________________
  #30
Old 20-09-19, 04:34 PM
OC3D Elite
You sir are approaching mad genius levels here. Like Ali Abbass levels of mad genius! Who the heck GROWS crystals for a build, that is so bloody awesome!!
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
