Go Back   OC3D Forums > [OC3D] Project Logs & Gallery > Rig Gallery
Thread Tools Display Modes
  #21
Old 13-05-19, 10:59 AM
AlienALX's Avatar
AlienALX AlienALX is online now
OC3D Elite
Next time I flush I'll get one of those, or the AC one. Pretty sure I have some fittings left.
__________________
  #22
Old 13-05-19, 02:52 PM
Bartacus Bartacus is offline
OC3D Elite
Originally Posted by Warchild View Post
The new CPU block is awesome. Is it possible to change oritentation? e.g. for some, who prefer to have the temp display above the tubes?
Nah, I don't think so. It's fixed in place. Great block though, but it's not priced as cheaply as their other stuff.
This would look really nice with hard tubing. Especially if you got the 45 bends nailed perfect.
That's why I didn't go hard tube. Even though it appears that way due to soft tube, there aren't any perfect 45 angles there. Everything is slightly off on one angle or another. Plus, hard tubes get displaced too easy when 'burping' the loop. If you get one length just a few mm short, they can pop out under 'duress'.
__________________
Guts: Ryzen 3900X / GB Aorus Master / 16GB TridentZ 3600CL15 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU / Case Labs M8
Storage: Corsair Force MP600 1TB NVME / 6TB RAID0 HDD array / 4TB RAID0 SSD array
Water Cooling: Watercool HeatKiller IV blocks on CPU & GPUs / 4 360 rads + 240 rad / Heatkiller reservoir / dual D5 pumps
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
