Go Back   OC3D Forums > [OC3D] Graphics & Displays > Graphics Cards
Thread Tools Display Modes
  #21
Old 16-06-19, 05:57 PM
Duckboy Duckboy is offline
Newbie
Originally Posted by NeverBackDown View Post
Could try updating drivers or using a slightly older one and maybe updating the GPU bios.
Other than that I would say return and replace.
I'll try some older drivers when I get the time, I am beginning to think it is a driver issue TBH, benchmarks its totally ok, zero issues, just gaming... it's a strange one...
I just don't get how I can run so many tests and it runs totally fine tho, 10min gaming...... higher temps and downclocking..... I've tested far cry 5, far cry new dawn, sleeping dogs, ride 3
I'm ruling out bad air flow, or added cpu heat, my system doesn't get hot, it never has, Hell I even crossfired 2 7850's and the temps wasn't too bad, and that rules out a bad psu too.....
I'll check to see if there's a new bios too
  #22
Old 16-06-19, 06:24 PM
Newbie
Well it turns out there are 2 versions of the pulse card, one has dual bios, the other doesn't.... I have the v1 version, no dual bios
  #23
Old 25-06-19, 08:21 PM
Newbie
It turns out after a reinstall of windows, new drivers, updates etc..... the card is working fine now, no afterburner or any other crap installed, undervolted states 4-7 1060mv from 1150mv, power limit +30, hovers around 68c and not throlling after hours of gamiing, couldn't be happier now..... if only they made these things just work 100% out of the box......
  #24
Old 25-06-19, 09:00 PM
AlienALX's Avatar
AlienALX AlienALX is online now
OC3D Elite
I've had issues with Afterburner on two PCs now and have had to remove it on both.
__________________
"Those really high 20 series prices are just place holders"
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
