Go Back   OC3D Forums > [OC3D] Cooling Forum > Air Cooling
Thread Tools Display Modes
  #1
Old 06-04-19, 02:05 PM
RobCharles1981 RobCharles1981 is offline
Member
Corsair H60 2018 Installation Problems on AMD Ryzen
Hi All
I recent invested in the Corsair H60 (2018 Edition) Hydro Cooler for my AMD Ryzen Processor and my Motherboard is the MSI B4350 Gaming Motherboard.
I have been recently having trouble in getting this to install onto my CPU and I duly ordered and had the AM4 Retention Bracket via Amazon and I installed the Blots the with the Stock AMD Back Plate. Then I ran into a snag where I wasn't sure how to install the pump. So it's apparent there I need to add something onto the pump but what? - I looked on Youtube for ideas too.
I eventually after a fiddle got the pump to install using the AMD Clips on the Stock Bracket.
So why won't the pump install with AM4 retention bracket?
Any pointers would be great!
Many thanks!
__________________
AMD Ryzen 5 2600. MSI B450 Gaming Motherboard Corsair H60, Corsair Vengenance LPX 16gig DDR3
Corsair TX 750m PSU, AMD R9 390: Creative Soundblaster Z: Fractal R5 Case
  #2
Old 06-04-19, 03:01 PM
Dawelio's Avatar
Dawelio Dawelio is offline
OC3D Elite
I found this post on Reddit that seems to be digging into your exact problem, I didn’t personally fully read into the whole thread, but seems to be something worth reading. Hope it helps:
https://www.google.com/amp/s/amp.red...iw/h60_on_am4/
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
