Go Back   OC3D Forums > [OC3D] Forum Teams > [OC3D] Benchmark Team
Thread Tools Display Modes
  #51
Old 28-03-19, 03:23 PM
WYP's Avatar
WYP WYP is offline
News Guru
Originally Posted by ET3D View Post
2133MHz DDR3 RAM.
Please edit your results to use the same formatting as eddie long's post above. This saves me a huge amount of time when updating the chart.
MT 3661 Intel 8700k @ 4.7ghz 3200 ddr4 Windows 10 eddie long
ST 485 Intel 8700k @ 4.7ghz 3200 ddr4 Windows 10 eddie long
__________________
_______________________________
Twitter - @WYP_PC
  #52
Old 28-03-19, 03:29 PM
ET3D ET3D is offline
Newbie
Got to go now. Will do it later.
  #53
Old 28-03-19, 03:53 PM
looz's Avatar
looz looz is offline
OC3D Elite
Oh man how dare you post an Atom score, I wonder if I could run that bench on raspberry pi using exagear and wine.
__________________
i7 8700k - 16GB - 2060 FE - 512GB 970 & 850 EVO - AKG K702
  #54
Old 28-03-19, 03:58 PM
tgrech tgrech is online now
OC3D Elite
Lol yeah my immediate though after that was whether Cinebench would work with Windows-on-ARM, but I think Cinebench might be x64 only which rules that way out.
  #55
Old 28-03-19, 04:58 PM
Newbie
MT 219cb, Core 2 Duo E6420, Stock, 800MHz DDR2, Windows 10, ET3D
ST 116cb, Core 2 Duo E6420, Stock, 800MHz DDR2, Windows 10, ET3D
  #56
Old 29-03-19, 08:40 AM
Newbie
MT 91cb, AMD E-350, Stock, 1066MHz DDR3, Windows 10, ET3D
ST 49cb, AMD E-350, Stock, 1066MHz DDR3, Windows 10, ET3D
This is the only time I ran the benchmark more than once, because the MT score of 76 looked too low compared to the ST score. I know that some processes (like the Lenovo ones) tend to take some CPU occasionally, so figured it would be worth trying again.
Also, CPU-Z reports the RAM sticks as 1333MHz DDR3, but running at 1066MHz.
I don't think I can go lower than this. I have weaker devices, but not with the minimum 4GB required for the test.
  #57
Old 29-03-19, 09:50 AM
WYP's Avatar
WYP WYP is offline
News Guru
I joked a while back that this thread was becoming a race to the bottom, but wow. Those scores are impressively low.
I am very happy to see these, but these results must have taken ages to get.
I'll update the leaderboard now.
__________________
Twitter - @WYP_PC
  #58
Old 29-03-19, 04:47 PM
Kei's Avatar
Kei Kei is offline
Advanced Member
Lol, it looks that way. I was going to dig my opteron 180 & dfi lanparty nf4 ultra out of mothball but I don't think it's quite bad enough as it oc'd to 3GHz quite nicely. That said, it probably doesn't support the necessary instruction sets.
__________________
Gigabyte Aorus X399 Gaming 7 ⁞⁞ Ryzen TR 1920x ⁞⁞ EK Blocks + αcool XT45 rads ⁞⁞ AMD Radeon Vega 56 ⁞⁞ 32GB 8 Pack 3200C14 ⁞⁞ Enthoo Primo
Seasonic Prime 750W ⁞⁞ Polaris 961 256GB ⁞⁞ 850 Pro 512GB ⁞⁞ M500 240GB ⁞⁞ WD Se 4TB & 1TB x2 ⁞⁞ Samsung C27HG70 + Dell 2408WFP
Ducky Shine 5 ⁞⁞ AJA Kona LSe ⁞⁞ RME HDSPe AIO ⁞⁞ Marantz AV7701 ⁞⁞ Tannoy SRM 10B ⁞⁞ AKG K601 ⁞⁞ Beyer DT770
  #59
Old 29-03-19, 04:59 PM
OC3D Elite
The fastest processor on the list is just shy of 113 times faster than the slowest, that's one hell of a spread.
  #60
Old 29-03-19, 05:08 PM
Eddie long's Avatar
Eddie long Eddie long is offline
Advanced Member
I see this is turning into a "How Low Can You Go"
__________________
Life isn't always a bowl of cherry's.
Sometimes it's HARD WORK
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
