Thread Tools Display Modes
  #31
Old 12-04-19, 11:03 AM
sheroo's Avatar
sheroo sheroo is offline
OC3D Elite
Lookin' great.
__________________
"All his life has he looked away... to the future, to the horizon. Never his mind on where he was."
  #32
Old 13-04-19, 07:55 AM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Nice!
I've got wood
__________________
"Those really high 20 series prices are just place holders"
  #33
Old 12-05-19, 02:22 PM
Jokot Jokot is offline
Newbie
Long time since last update, will try and make up for it with a longer one then usual
First of I finished all the wood working and added the corner pieces that will be holding the front and back pieces in place
Not a single screw will be used for the wood frame itself its all held together with wood joints so it was really solid even before applying glue.
Here is plexi for the side windows.
This is what it looked like when it was all clamped in for the glue to dry.
I really like how the bends turned out with the different layers.
Front and back are made of some spare material I found, actually have no idea what its called. But Its made up of some kind of plastic in the middle and very thin aluminum on both sides, that made if very easy to machine with wood tools.
Made a wooden jig to help with cutting the holes for the front intake fans, and it worked really well. And thanks Mnpctech for the awesome template
  #34
Old 12-05-19, 02:38 PM
AlienALX's Avatar
OC3D Elite
Very nice. I do love working with plexi. You can get good results without thousands of dollars/pounds worth of machinery.
__________________
  #35
Old 12-05-19, 02:59 PM
Newbie
Oh yeah, the material I used for front and back is also very easy to work with and you get a aluminum look
Tags
itx, scratch build, wood
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
