Thread Tools Display Modes
  #11
Old 28-02-19, 08:49 AM
Jokot Jokot is offline
Newbie
Originally Posted by hmmblah View Post
Interesting build, is it going to be solid wood or will you use lamination to get the bends?
Will be using thin plywood sheets for the bends
  #12
Old 28-02-19, 08:56 AM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
All you need to do is dive too deep......
I'd imagine you would need to use steam for bends that tight.
__________________
  #13
Old 28-02-19, 09:56 AM
Warchild Warchild is offline
OC3D Elite
Bends at 90degree may need gradual steaming and curing. Much like an acoustic guitar.
  #14
Old 28-02-19, 12:52 PM
hmmblah's Avatar
hmmblah hmmblah is offline
Moderator
Looking forward to see how this comes together.
LOL...ashamed to admit that took me a minute.
__________________
CaseLabs Mercury S3 | AMD 3900X | ROG CH8 Impact | RTX 2080 Super | 16GB DDR4 | 1TB NVMe
Acer Predator Z35P
  #15
Old 28-02-19, 07:26 PM
Newbie
The material just needs to be thin enough and using a damp rag on the sheets will help before bending and gluing
  #16
Old 04-03-19, 03:33 PM
Newbie
So this is how I will be bending and making the top and bottom "handles"
I need something to bend the thin sheets around so that was part 1 of the process and that was easily done with some MDF scrap pieces.
Here is the template rounded and covered in tape to avoid the glue from sticking.
Here is the material I will be using.
I also made a outer part for the template by bending 5mm plywood, that will also help equalize the pressure along the curve.
And now ever thing is ready to be glued together and clamped down, the grain of each sheet is going against each other to get a stronger final product. You can also see the template was made with "shelves" to make clamping easier.
Here is a better picture of the layers.
And I also made a second one the next day.
  #17
Old 04-03-19, 05:42 PM
Pugsport Pugsport is offline
Advanced Member
good progress, can not wait to see how this turns out, i really want to make a solid oak case
did you over bend them to allow for spring back?
  #18
Old 04-03-19, 06:31 PM
Newbie
I did some quick tests and spring back was minimal when grain of each sheet is going against each other
  #19
Old 10-03-19, 10:37 AM
Newbie
More work on the handles.
I made grooves in the handles using the big router in previous picture.
Now just cut both of those in half and I will have my four handels.
And a few pictures without tape.
  #20
Old 10-03-19, 10:59 AM
Davva2004's Avatar
Davva2004 Davva2004 is offline
OC3D Elite
Wow. Proper nice.
__________________
Tags
itx, scratch build, wood
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
