Thread Tools Display Modes
  #11
Old 03-03-19, 04:49 PM
Pugsport Pugsport is offline
Advanced Member
finally started putting the numbers on the sides of the dice this afternoon
right hand side of dice, number 5 although the 5th is in the lid, i did also start trimming up the front edge around the lid to (not sure how well it show up here though
view from inside
  #12
Old 04-03-19, 05:54 PM
Advanced Member
got a little more done today
left side of done, number two
right side just need one more hole in the lid for number five
back is good now
front needs two more holes cut for number three
lid is just sat in place for now
tomorrows jobs are cut the six holes in the bottom, fix the lid in place and try to get the rest of the holes cut in, then its prep and paint
thinking of going white on the outside and this on the inside with maybe some detail on the outside
  #13
Old 05-03-19, 09:14 PM
Advanced Member
well got another six holes done today and the lid fitted but if im honest im losing interest in this as i have no real plans at the moment to use it but still plan to paint it then maybe store or get rid of it
six cut in the underside of case
lid fitted and marked out the other two holes on front face
single hole marked out on the top face
  #14
Old 06-03-19, 04:19 AM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Oooooo custom paint !
Now you have my full attention
__________________
  #15
Old 07-03-19, 09:23 PM
Advanced Member
well that depends what you mean by custom paint? because as this was/is my first welding/metal work project its no where near straight, i welded it to fast but lesson learnt on that one as well as some other things I've learnt along the way.
but my plans for paint, if i can get it straight enough are
option one
option two
third option is to do a 3 stage paint job on it with white base, purple detail like above and then 3rd stage would be purple intercoat all over
feel free to input on which option or any ideas as this was only ever a test project and no real plan at the moment to use it.
started making it straight with some filler, id really like it to be arrow straight before painting it
this was progress from yesterday as today ive not felt up to do anything and its been cold and windy outside so maybe tomorrow we can get it paint ready
  #16
Old 08-03-19, 11:47 AM
AlienALX's Avatar
OC3D Elite
Can you not paint it red sparkle like a Vegas dice? that, with a white interior would look incredible.
__________________
  #17
Old 08-03-19, 06:27 PM
Advanced Member
something like this red with a solid white interior
  #18
Old 08-03-19, 08:11 PM
AlienALX's Avatar
OC3D Elite
Yup totally man!
__________________
  #19
Old 09-03-19, 06:29 PM
Advanced Member
bit more filler work done today
Testing the colour
metallic silver basecoat
candy red over the top, photo does not show up the metallic very well, ill get some more shot if its sunny soon
  #20
Old 09-03-19, 07:46 PM
AlienALX's Avatar
OC3D Elite
Amazeballs. I love candy haha. It's hard to paint too, so props for that.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
