Go Back   OC3D Forums > [OC3D] Graphics & Displays > Graphics Cards
Thread Tools Display Modes
  #11
Old 30-01-19, 06:41 PM
Highlander89's Avatar
Highlander89 Highlander89 is offline
Advanced Member
Originally Posted by AlienALX View Post
I typed up some more but then pizza came lol. Also, look at the back plate of the card in question and compare the screw holes to a stock PCB. I believe GamersNexus have stripped one.
PIZZA!!
Couldn't find the article you mentioned, but Hexus did a review about the Gigabyte Windforce
Stripping it to the bare PCB, Gigabyte keeps costs in check by adopting what appears to be a reference-style PCB. That means a 10in-long card, 8+6-pin power connectors, and a lack of SLI connectors.
According to the review, Gigabyte seems like a good card. Good overclocker but noisy fan.
Lucky a full cover waterblock isn't noisy :P Aaand, a backplate is included!
__________________
I7 4790K -- Asus Z97-AR -- GTX 770 4GB -- 16GB DDR3
840 EVO -- WD Green 3TB -- CS 750M -- NZXT 810 -- BenQ GL2450 -- Asus ROG PG279Q
XSPC Raystorm -- Heatkiller GPU X3 -- Alphacool D5 -- Noiseblocker Blacksilent -- 420 & 360 Nexxos UT60
--P180 Resurrection--
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
