Go Back   OC3D Forums > [OC3D] Off Topic > Off Topic Chat > Serious Discussion
Thread Tools Display Modes
  #21
Old 16-01-19, 06:40 AM
FTLN FTLN is offline
OC3D Elite
Looks like a problem with the server, same error on my side too.
You can run a server locally by running another instance of iperf3 on another pc using this command : iperf3 -s
Just make sure to allow it in the firewall on port 5201 usually
__________________
Intel Core i9 9900kK @ 5.00GHz @1.275v - Asus ROG Maximus Hero - Corsair 3000mhz CL16 LED 4x16GB SKHYNIX - Thermal Take View Glass - PM961 1TB x 2 RAID0 - Nvidia GTX 1080 Ti - Corsair H110i - Corsair Commander Pro - Asus ROG Swift PG279Q 2560x1440P G-Sync 165Hz
  #22
Old 16-01-19, 08:34 AM
SPS SPS is offline
Moderator
Go to Windows services, find Cryptographic Service, stop it and then open and load a page in Chrome, has it improved? NB: Cryptographic Service will restart itself at some point.
__________________
  #23
Old 16-01-19, 08:44 AM
Warchild Warchild is offline
OC3D Elite
Originally Posted by FTLN View Post
You need to open a cmd window in the folder where you unzipped iperf3
easy way to do that is open the folder where it is unzipped and in the explorer address bar type cmd, a cmd window will open and you can copy in the command I mentioned previously.
I think thats going much deeper than it needs to be. For his issues, speedtest.net is actually adequate enough.
But my question, is if the wireless dongle, wireless network card or whatever is being used, is capable of the 100Gb/s throughput?
My current wifi card running on my laptop is only capable of 60 where as my network is 500.
  #24
Old 22-01-19, 05:54 AM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
Ok so I got iperf3 to run this is the result
__________________
DRAGON'S MIST
NZXT Phantom 630 White=AMD Ryzen 1700X=MSI X370 Gaming M7 ACK=Intel Optane SSD 9 480GB PCIE=32gig 3200Mhz GSkill Flare X= MSI GTX1080 Seahawk X=NZXT Kraken X62=MSI MPG341CQR=MSI GK80 Vigor=Corsair Force LS 960GB=Cougar 700M=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with Aer RGB fans and RBG strip=Pioneer BDR-209D=Windows 10 Pro=Thrustmaster T16000M HOTAS=Corsair MM800 RGB CE
  #25
Old 22-01-19, 06:55 AM
SPS SPS is offline
Moderator
Did you try my suggestion above?
__________________
  #26
Old 22-01-19, 09:05 AM
OC3D Elite
Sorry Mate I missed your post and no I haven't tried it yet but one thing I did do and it seems to have improved things a little is when using Firefox I changed,
Use system proxy settings to Auto detect proxy settings and for the most part the delays are lessened.
Will doing what you suggest work for Firefox too?
__________________
DRAGON'S MIST
  #27
Old 22-01-19, 09:09 AM
SPS SPS is offline
Moderator
It's a windows thing. You've tried other browsers right? Firefox produces far too many bugs to rely on IMO, which is sad. I had to go back to Chrome.
__________________
  #28
Old 22-01-19, 10:33 AM
OC3D Elite
Yes I tried going back to chrome myself but it was interfering with a program that I have to run called Fleetmatics which it never used to do before but started not loading it properly so I've had to stick with firefox but luckily since I made those changes that I talked about earlier things have been much better and my ISP is still liaising with NBN Co to see if the new code that they implemented to get my net running correctly might be adversely affecting it
__________________
DRAGON'S MIST
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
