Go Back   OC3D Forums > [OC3D] Processors & Platforms > Memory
Thread Tools Display Modes
  #11
Old 14-01-19, 09:28 AM
tinytomlogan's Avatar
The Guvnor
Thats the voltage that stabilises ram speeds.
Try 1.1v to start
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #12
Old 14-01-19, 09:54 AM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
Try 1.1v to start
It auto sets to 1.137 and honestly I'm fine with 3000MHz, All the timings are at their rated speeds but if anything gives I'll then start to tinker.
Thanks for the input Guv
__________________
- Intel Core i9 9900K @ 5GHz - Asus ROG Max XI Hero -
- Corsair Vengeance Pro RGB 4x8GB @ 3600MHz -
- WD Black SN750 1TB - RTX 2080 Ti @ 2000/7500 -
- Windows 10 Pro 64 Bit Edition - Corsair 680X Black -
  #13
Old 14-01-19, 09:07 PM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
Originally Posted by Dicehunter View Post
I installed the 3200MHz memory just after 1809 landed and it sat happily at 3200 for a good few weeks and all of a sudden it simply doesn't work at anything over 3000MHz, It's not that it won't boot into Windows, It won't even make it to the bios screen.
Maybe running it at 3200MHz was just a fluke
I was getting an error 55 and my system wouldn't boot either, I had to clear CMOS then reset to default then enable AXMP then it worked for awhile then I kept getting BSOD's so took out 16 and away it went, even tried reformatting at first thinking it was that but you can't even install Windows with 32 you have to do it with 16 then put the rest in after..............
__________________
DRAGON'S MIST
NZXT Phantom 630 White=AMD Ryzen 1700X=MSI X370 Gaming M7 ACK=Intel Optane SSD 9 480GB PCIE=32gig 3200Mhz GSkill Flare X= MSI GTX1080 Seahawk X=NZXT Kraken X62=MSI MPG341CQR=MSI GK80 Vigor=Corsair Force LS 960GB=Cougar 700M=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with Aer RGB fans and RBG strip=Pioneer BDR-209D=Windows 10 Pro=Thrustmaster T16000M HOTAS=Corsair MM800 RGB CE
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
