Go Back   OC3D Forums > [OC3D] Hardware & Software > Cases & Power
Thread Tools Display Modes
  #11
Old 29-04-19, 10:17 AM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Is 600w even enough for a 9900k and 1080ti?
That may cut it close.
__________________
"Those really high 20 series prices are just place holders"
  #12
Old 29-04-19, 11:13 AM
SuB's Avatar
SuB SuB is offline
The Webmaster
850w*
__________________
Gigabyte Z390 Aorus Pro | i7-8700k | 32GB Corsair Vengeance 3000Mhz DDR4 | nVidia RTX 2080Ti | Creative Audigy Rx | 1Tb Samsung 970 EVO+ M.2 | 1TB Samsung 860 QVO | 2TB Seagate Barracuda | Corsair RM850 | Fractal Define S | Noctua NH-U14S | Roccat Kone Optical - Navy Storm | QPad MK85 Pro w/ Cherry Red MX | DELL U2413 + 2 x U2412M | AKG K702's | AKG K7XX S/N#000016 | Beyerdynamic DT770 Pro 250Ohm | TM Hotas Warthog Stick and Throttle | Saitek Combat Pro Pedals | TrackIR 5 | TrackClip Pro
Notice: Don't feed the trolls!
  #13
Old 29-04-19, 12:43 PM
tgrech tgrech is offline
OC3D Elite
[TL;DR: A Titanium PSU will output almost half the heat of a Gold rated PSU(~6% of draw as heat vs 10%) most of the time and therefore should require less active cooling.]
Originally Posted by SuB View Post
Having more headroom (so having the 1000w) = the fans will stay off for more time (especially on an RM) and will run quieter and cooler overall,.
Having less watts (850w) = driving that harder = probably more noise...
It really is mostly that simple, you're correct.
Well, sort of, a higher rated PSU should be have better cooling to match, but the noise is a result of moving the waste heat energy, the waste heat energy is calculated from the efficiency. A titanium 850W PSU should be 4% more efficient in the main power band(40-60% load), with that rising to 5% just beyond that, and critically any PSU below a Titanium doesn't have an efficiency certified for idle or heavy loads, so that gap could widen further outside of 25-75% load. For a Gold rated PSU you typically see curves like this(Image from Corsair):
I know 4-6% efficiency might not sound like a lot, but if you're pulling 600W that's ~25W of heat (Titanium 230V peak eff.) vs ~50W(Gold 230V peak eff.), which very well could be the difference between fans spinning or not, and remembering peak efficiency is the best case scenario of comparison for the Gold PSU(Though ofc at lower wattages the absolute gap shrinks even if the %age eff. widens).
Using an overspec'd PSU also harms efficiency in itself(Though ofc so does using a heavily underspec'd one), if they're not in that 25%+ load gap most of the time(And it's very rare your PC would draw 250W+ unless under notable load), then their PSU won't be running to a rated efficiency at all with a Gold, while with the 850W Titanium it'd be in its rated efficiency range as low as 85W. Assuming they rarely go over 750W load (Which would take some serious overclocking with those parts, remembering this is not load at the wall we're worrying about which is typically 10-20% higher, those parts would probably have an internal draw of about 500W while gaming) the Titanium 850W should be roundly more efficient and therefore quieter assuming roughly equivalent fans & internal dissipation rate.
  #14
Old 29-04-19, 01:19 PM
Dawelio's Avatar
Dawelio Dawelio is offline
OC3D Elite
Really? Would think the opposite - that an higher rated PSU would do it better, ie the AX (Titanium) over the RM (Gold).
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
