Thread Tools Display Modes
  #21
Old 04-02-19, 03:43 PM
Eddie long's Avatar
Eddie long Eddie long is offline
Advanced Member
Originally Posted by tinytomlogan View Post
Corrr blimey this is one heck of an upgrade dude!
Which in no small part is thanks to you and the competition , didn't want to just throw it in a box , wanted to make it worthy of posting
__________________
Life isn't always a bowl of cherry's.
Sometimes it's HARD WORK
  #22
Old 08-02-19, 05:21 PM
Eddie long's Avatar
Advanced Member
Quick update
I have been having a few issues with the phanteks fan hub , not registering rpm , running fans a different speeds , basically doing its own thing , looked at a couple of forums and i seem to not be the only one , so until phanteks can replace it i have ordered 2 x aquacomputer splitty 9 , so i position them in the correct places .
Also while i was on the order i also got 2 xspc rgb splitters as using cable splitters doesn't seem idea , will update with pic's later
__________________
  #23
Old 08-02-19, 05:32 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
I tend to avoid everything NZXT, Phanteks, Asus and etc. Aquacomputer are simply better at everything they do.
The XSPC RGB splitters are very good. I am running two of those
__________________
  #24
Old 08-02-19, 05:50 PM
Eddie long's Avatar
Advanced Member
well that sound good for the xspc splitters , and even when phanteks replace the hub i may just not use it
__________________
  #25
Old 08-02-19, 06:14 PM
AlienALX's Avatar
OC3D Elite
What it inevitably always comes back to dude is the software. You can design the most elaborate hardware in the universe but if the software sucks.....
And that is where Aquacomputer have it completely nailed. Aquasuite is simply the best software out there. Everything works exactly as it should, they constantly update the firmware and etc to make everything work properly.
That is where Asus seem to falter. I mean, their latest software is detected as spyware and actually prevents some games from running as the game thinks you are running cheat code. I found that out when my buddy could not get Far Cry 5 to run. Took us hours of messing around.
__________________
  #26
Old 09-02-19, 08:36 AM
Eddie long's Avatar
Advanced Member
The extras have turned up
Time to get on with it
__________________
  #27
Old 12-02-19, 09:40 PM
Eddie long's Avatar
Advanced Member
After some very hinky fan behaviour i finally gave up with splitty 9's and got a couple of ek 3 way splitters and a couple of extension cables , seems to have worked .
So finally it is finished
cable management done to the best of my abilities
Bios updated and drivers to the latest all seems good
Hope you all enjoyed my efforts .
Thanks again to Tom for the chance of entering a competition which without of this chance may have not ever happened
__________________
  #28
Old 12-02-19, 10:20 PM
Dark NighT's Avatar
Dark NighT Dark NighT is offline
OC3D Elite
That is looking pretty cool dude!
The gpu deserves to be vertical like that, it is looking fantastic.
  #29
Old 12-02-19, 10:39 PM
AlienALX's Avatar
OC3D Elite
I like it. Like the green too.
__________________
  #30
Old 13-02-19, 04:32 PM
Eddie long's Avatar
Advanced Member
thank you , it had to go that way to show it off , also its got a full slot between the fan and the glass ,so hopefully won't get too warm
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
