Go Back   OC3D Forums > [OC3D] Project Logs & Gallery > Rig Gallery
Thread Tools Display Modes
  #1
Old 05-01-19, 11:57 PM
Shellback_Tech Shellback_Tech is offline
Newbie
Talking H500P Mesh White Build
Newcomer. Let's see if I get this post right. I messed the other 2 posts up. This is the culmination of a ton of work. I started out in an NZXT S340 Elite White, but found that the rad was choking off the intake side and overheating my system.
Parts List:
i7-8700K @5.0Ghz
32GB G.Skill Trident Z RGB 3000Mhz
Asus Rog Strix OC Edition GTX 1080ti
Asus Prime Z370A
NZXT Kraken X62
WD Black 500GB NVME
2TB Seagate BarracudaHDD
2TB Toshiba 7200rpm HDD
EVGA Supernova G3 750W
Cooler Master H500P Mesh White
Corsair K55 and M65
Acer Predator Z1 32" Curved 2560x1440 165Hz OC
Sceptre 1080p 32" Curved 75Hz
Logitech C922x
CableMod Basic Black and White Cable Extension Kit
Phanteks RGB Strips x2
  #2
Old 06-01-19, 01:54 PM
WYP's Avatar
WYP WYP is online now
News Guru
Small mistake for your images again.
For images, you need to link the image itself, not the webpage where it is.
For example, you posted this between the image tags;
https://imgur.com/giIxUax
When you needed to post this;
https://i.imgur.com/giIxUax.jpg
The easiest way of getting an image link is by right clicking on your image and selecting "copy image address". Otherwise, no images will appear on your post.
__________________
_______________________________
Twitter - @WYP_PC
  #3
Old 07-01-19, 03:05 AM
Newbie
Ahhh! See what happens when you're not familiar with forums. Last time I did this kind of thing was when I built my old truck and the way they did things was vastly different. Still learning etiquette. Thanks for understanding.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
