Thread Tools Display Modes
  #11
Old 19-11-18, 08:55 PM
AlienALX's Avatar
AlienALX AlienALX is online now
OC3D Elite
Putting that sort of money into DDR3 is a false economy, IMO. You will never get anything like that when you come to sell it later.
__________________
If you don't like what I post don't read it.
  #12
Old 20-11-18, 07:43 PM
RobCharles1981 RobCharles1981 is offline
Member
Originally Posted by Davva2004 View Post
At £400, you can afford either the CPU and mobo OR the GPU. If your video editing software uses the GPU for hardware acceleration, put the money into that and you also get to benefit from gaming on it.
This will get you a 120mm AIO cooler so you can overclock your CPU, 16GB of DDR3-2400 memory (in blue, so it matches your board) and a GTX1060 6GB which is the perfect 1080P gaming card with plenty of CUDA cores for video encoding.
https://uk.pcpartpicker.com/list/nbsMr6
This is what I may go down the road with, as it looks the better option!
I'm also debating on getting a Water Pump Corsair H Series what can you recommend?
__________________
AMD Ryzen 5 2600. MSI B450 Gaming Motherboard Corsair H60, Corsair Vengenance LPX 16gig DDR3
Corsair TX 750m PSU, AMD R9 390: Creative Soundblaster Z: Fractal R5 Case
  #13
Old 21-11-18, 12:54 AM
AMD Enthusiast
You'd better off with an air cooler than a 120mm AIO tbh. 120mm AIOs are not worth it especially the cheap ones. Just my 2 cents. I'd get a nice Cryorig H7, if you wanted to spend more on the AIO then any of the NZXT or Corsair 240mm are worth it.
  #14
Old 21-11-18, 02:35 AM
looz's Avatar
looz looz is offline
OC3D Elite
Honestly I don't see the point of AIOs at all, they sit awkwardly between high end air coolers and a proper custom loop. Sure, they're convenient, but they're only slightly better than a proper air cooler yet cost more, are louder and more prone to failure.
AIOs make sense in compact setups where there's no space for an air cooler, otherwise I'd steer clear. I regret buying into this fad.
Also, what, why would he go from r9 390 to a GTX 1060? They,re really close in performance, sure the GTX is more power efficient but that's about it. Similarly, why would he swap NH-U12S to a 120mm AIO? Even in cooling power that's a sidegrade.
For editing the Ivy Bridge i5 is showing its age, I'd personally save up until Ryzen upgrade (either 6 core or even 8 core) is feasible, and sell the ivy CPU/DDR/Mobo. A 2600 would cool well under that Noctua, be night and day in video editing and provide a slight boost in gaming. That would also be a platform you could build on in the future.
Example: https://uk.pcpartpicker.com/list/z82vbX at £388, would result in a respectable gaming/editing setup especially for 1080p. I don't know how much a 3570k/8gig/Z77 would sell for, maybe £140 is in the ballpark? Either way, you could easily fit a case in that budget as well, after selling the old hardware.
__________________
i7 8700k - 16GB - 2060 FE - 660p 1TB + MX500 2TB - HE-4XX w/ Topping D30+A30
  #15
Old 21-11-18, 05:49 AM
AlienALX's Avatar
OC3D Elite
AIO are good because they allow much easier and better access to your motherboard without ripping your hands to shreds. They also put much less pressure on the PCB. If you move your rig around a lot (LAN maybe) they are a much better option.
I agree that a 120 is not good enough if you are overclocking, though.
And yeah, I think spending that on DDR3 now is a complete waste of money but ho hum I said what I had to say. And yeah the 3570k is really beginning to show its age now, because Sandy is too and it clocked higher so there was nothing in it.
__________________
  #16
Old 18-02-19, 05:07 PM
Member
So I'm back
Ready to make my purchase.
I'm still deciding on what Motherboard I should go with, I have two ideas:
https://www.ebuyer.com/854868-msi-b4...-b450-tomahawk
or
https://www.ebuyer.com/854871-msi-b4...50-gaming-plus
Any ideas?
Thanks
Rob
__________________
  #17
Old 18-02-19, 06:16 PM
Dark NighT's Avatar
Dark NighT Dark NighT is offline
OC3D Elite
Get the one you like most in terms of colors or theme, they both fine boards.
  #18
Old 18-02-19, 07:05 PM
Member
Do either Overclock well ???
__________________
  #19
Old 18-02-19, 09:01 PM
Dark NighT's Avatar
OC3D Elite
Not really, both have serviceable VRM's and you could probably get a little more out of the cpu, but seeing as you are going ryzen, and most of those tap out at 4.2 or 4.3 ghz, i wouldn't stress to much about it as ryzen 2 prettymuch boosts up to those frequencies on its own as long as the temperatures allow it.
  #20
Old 19-02-19, 12:37 AM
NickOmega's Avatar
NickOmega NickOmega is offline
OC3D Crew
Of those two I'd go with the Tomahawk which was originally my own selection, but then I opted for the MSI B450 Gaming Pro Carbon since it has the same VRM as their X470 Gaming Plus.
Downside being lack of voltage offset control on MSI bios.
__________________
Ryzen 5 2600X -- EVGA GTX 1070 SC -- 16GB TeamGroup Dark Pro 3200mhz DDR4
MSI B450 Gaming Pro Carbon -- Corsair Force MP300 240GB
Seasonic Focus Gold 750 -- Phanteks P350X
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
