Go Back   OC3D Forums > [OC3D] Cooling Forum > Air Cooling
Thread Tools Display Modes
  #31
Old 19-10-18, 12:12 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Originally Posted by Dicehunter View Post
So apparently it wasn't all my blondness, I noticed that in games the CPU was getting up to 80'c, Took the cooler off and swapped it out for the Wraith Prism cooler that came with my 2700X and apparently it looks like the Wraith that came with my mates 2700X has an ever so slightly warped cooling plate, Meaning it does not make full contact with the CPU.
To be fair I didn't roast you too much because I *hate* those plastic push pins. I remember once my Intel cooler came off, and I had to use more than reasonable force to eventually get it on correctly. They should stop making them like that tbh. Horrible things.
__________________
"Those really high 20 series prices are just place holders"
  #32
Old 19-10-18, 12:49 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
The AMD stock cooler is actually pretty good in that respect as you just hook both loops of the cooler onto the board and pull the level all the way to the opposite side, But even then it can't exactly make up for a warped cooling plate.
__________________
- Intel Core i9 9900K @ 5GHz - Asus ROG Max XI Hero -
- Corsair Vengeance Pro RGB 4x8GB @ 3600MHz -
- WD Black SN750 1TB - RTX 2080 Ti @ 2000/7500 -
- Windows 10 Pro 64 Bit Edition - Corsair 680X Black -
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
