Go Back   OC3D Forums > [OC3D] Processors & Platforms > Overclocking
Thread Tools Display Modes
  #1
Old 25-09-18, 05:49 PM
Samuel Samuel is offline
Newbie
6850K Overclock breaks after 2 years
I have had my 6850k running at 4.2Ghz @1.29v on a Asus x99-A II motherboard for over 2 years with no problems, I was running the Timespy benchmarks yesterday and several runs where fine then the cpu score dropped a few hundred points, I checked and the 6850k was running at 3.8Ghz on all but the 6th core which was running at 4Ghz. I have tried clearing the bios, changing to a different bios, even reinstalling windows to fix this but even though the overclock shows in the bios the multiplier doesn't seem to hold when windows boots up and it always reverts to 3.8Ghz on the first five cores and 4Ghz on the sixth.
Also to add to my confusion within windows I can use Intel Extreme Tuning Utility get the 4.2 overclock back but it looses it as soon as windows is restarted.
This shouldn't have been a heat issue, I have a H115i and the temps rarely hit 60c. I reverted to 3.8GHz across all the cores and it is perfectly stable. If I can't fix this it might give me an excuse to buy a new z390 mobo and the 9900k whenever it is released.
  #2
Old 25-09-18, 08:43 PM
Davva2004's Avatar
Davva2004 Davva2004 is offline
OC3D Elite
Silicon ages over time, especially when CPU’s are overclocked.
__________________
  #3
Old 26-09-18, 12:13 PM
WYP's Avatar
WYP WYP is offline
News Guru
Your silicon may have degraded a little over the years. It probably needs a higher voltage now to maintain 4.2GHz.
__________________
_______________________________
Twitter - @WYP_PC
  #4
Old 26-09-18, 12:44 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
It could be a whole wealth of factors.
1. Silicon degradation.
2. VRM degradation (the most likely culprit)
3. Spectre patches, or some sort of BIOS change.
__________________
  #5
Old 28-09-18, 08:14 PM
Flux Flux is offline
Member
Just found this on hexus . net
Windows 10 KB4100347 update breaks Broadwell-E overclocking
Did you install the KB4100347 update?
Might be worth looking into.
__________________
NEW PC: i7 5820K | Gigabyte GA-X99 Ultra Gaming RGB | Corsair DDR4 Vengeance LED, PC4-24000 (3000) | Nzxt Kraken x62 | Evga gtx 1070 sc 8gb | Corsair AX850 | CM Storm Stryker
OLD PC: i5 3570K | MSI Z77 MPower | Mushkin Ridgeback 2x4GB | Corsair H100i | XFI HD 7990 6GB | Corsair AX850 | CM Storm Stryker
  #6
Old 28-09-18, 10:15 PM
AlienALX's Avatar
OC3D Elite
Yup definitely. I'll need to check that myself tbh, given both rigs I use are BE and overclocked lol.
__________________
  #7
Old 28-09-18, 11:28 PM
Dark NighT's Avatar
Dark NighT Dark NighT is offline
OC3D Elite
I will have a look tomorrow to see if i got it installed but so far my oc is holding up just fine.
  #8
Old 29-09-18, 03:32 AM
Newbie
Fixed!!
That fixed it I uninstalled that update and the overclock if fine now, stupid windows breaking a perfectly good overclock. Thanks a lot for the help.
  #9
Old 29-09-18, 08:20 AM
Dawelio's Avatar
Dawelio Dawelio is offline
OC3D Elite
It wasn’t Windows that broke it, it was the update for windows.
  #10
Old 29-09-18, 06:16 PM
Member
Glad its working now
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
