Go Back   OC3D Forums > [OC3D] Customer Care Forums > Asus UK Customer Care Forums
Thread Tools Display Modes
  #1
Old 16-09-18, 11:24 AM
tolagarf's Avatar
tolagarf tolagarf is offline
OC3D Crew
Asus Z270i Strix Board Failure
So I've had two of these motherboards now that had issues from new. The first one (which was back in 2017) would fail to cold boot once XMP had been enabled, which were tested on two separate types of memory sets (different speeds, brand etc) and the only way I could get sign of life was to remove the battery, then remove one memory module and cold boot it. Once both RAM slots were populated, XMP enabled, same problem, rinse and repeat...
The second board which I bought couple of days ago, the PCI-e x16 slot is completely dead! No warning signs or anything in Windows device manager, no graphics card detected. BIOS reports slot speed as "none". Tested with two gfx cards, no dice!
What the heck is it with these ITX boards? Are they prone to more failures due to their small size? Just a thought as both these boards had a slight warped PCB. Now I gotta order my 3rd board, starting to wonder if I should go with another brand
  #2
Old 16-09-18, 11:27 AM
Dawelio's Avatar
Dawelio Dawelio is offline
OC3D Elite
I think I’ve had this board before and also recently had the AMD counterpart, X370-I Strix, and I never had any issues with either. Sounds to me that you’ve just been very unlucky with 2 boards. Hope this third one is a charm though
  #3
Old 16-09-18, 01:07 PM
tolagarf's Avatar
OC3D Crew
Dude... Unlucky is my middle name when it comes to hardware!
  #4
Old 16-09-18, 01:39 PM
Dawelio's Avatar
OC3D Elite
Haha, I see... Well fingers crossed then that your luck changes this time around
  #5
Old 16-09-18, 01:53 PM
Korreborg's Avatar
Korreborg Korreborg is offline
OC3D Crew
If you generally have problems with hardware it could be the power delivery in your home :/
__________________
[I9-7900X][Asus Strix X299-E][EVGA 1080TI FE][Corsair 16GB 3733MHz][Fractal Meshify C][Corsair AX860i]
[Samsung 970evo 500GB+1000GB of mixed SATA SDD's][ASUS PG278QR][Logitech G510s and G502][Steelseries Wireless H]
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
