Go Back   OC3D Forums > [OC3D] Hardware & Software > Software Section > Games
Thread Tools Display Modes
  #11
Old 23-08-18, 05:48 PM
RobM's Avatar
RobM RobM is offline
OC3D Elite
Originally Posted by looz View Post
Well, you can get quite far with just lsblk and blkid, if you want something similar to Windows' partition manager you can install gparted. It shows the /dev/sdXY as well. It's mainly a partitioning tool though so avoid hitting Apply in this case.
Edit: Oh there are graphical tools for it, KDiskFree seems quite decent.
yeah I found it got the drives mounted but getting games sorted is meh not seeing an option to add my library only folders and no navigation out of the default location so tried install to existing location but get error about not having permission.
I can get Steam running no problem without using the steam play so dunnow whats wrong anyhoo gonna boot back windows and have a few hours gaming
__________________
ASUS Prime x370 Pro | Ryzen 5 1600 | Antec 240 AIO | Corsair Vengance RGB 3000 2 x 8Gb | Asus Strix RX 470 | Samsung Evo 120gb ssd | Seagate Baracuda 1tb storage | EVGA 500w | Phanteks Entho ProM Acrylic Window | Windows 10 and Linux Manjaro
  #12
Old 24-08-18, 06:07 AM
Daiyus's Avatar
Daiyus Daiyus is offline
OC3D Crew
Originally Posted by Daiyus View Post
DOOM (2016):
- No option to select 2160p even though I have a 2160p monitor.
I found the solution to this one. My desktop was set to 150% scaling which was limiting the maximum resolution of the game; also the same situation on other games that run. Setting it to 100% allowed me to select 2160p. Annoying, but at least now we know.
I tested five more games last night:
BioShock Remastered:
- Not whitelisted.
- Black box (meant to be a BioShock banner) shows.
- Stops running. No error codes or hanging.
BioShock 2 Remastered:
- Not whitelisted.
- BioShock 2 banner shows.
Enslaved - Odyssey to the West:
- Not whitelisted.
- Doesn't start. No error codes or hanging.
Remember Me:
- Not whitelisted.
- Starts.
- Runs at lower performance than Windows; choppy framerate at 1440p.
- The first level was otherwise perfectly playable.
Rocksmith 2014 Remastered:
- Not whitelisted.
- Rocksmith provides error code when trying to start.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
