Go Back   OC3D Forums > [OC3D] Cooling Forum > Air Cooling
Thread Tools Display Modes
  #11
Old 14-07-18, 10:46 AM
ZeroInfinity94 ZeroInfinity94 is offline
Member
Nope no other cables in the box just the connector in the first post.
  #12
Old 14-07-18, 12:53 PM
Damien c Damien c is offline
OC3D Elite
After looking around on the net it would appear that the connector is a power and rgb connector.
Basically instead of doing like most companies in using iirc a single or dual lead setup, this company has decided that you would need a control box in order to power them and setup the RGB.
My advice return them and buy some decent fans, from a decent supplier like OCUK, Scan, Aria etc etc
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
