Go Back   OC3D Forums > [OC3D] Customer Care Forums > Asus UK Customer Care Forums
Thread Tools Display Modes
  #1
Old 13-07-18, 12:29 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
ROG Spatha Battery Degradation ?
Just curious but what is the expected total life span of the battery inside the Spatha before it can no longer hold a charge or the battery runs out very quickly ?
__________________
- Intel Core i9 9900K @ 5GHz - Asus ROG Max XI Hero -
- Corsair Vengeance Pro RGB 4x8GB @ 3600MHz -
- WD Black SN750 1TB - RTX 2080 Ti @ 2000/7500 -
- Windows 10 Pro 64 Bit Edition - Corsair 680X Black -
  #2
Old 13-07-18, 07:03 PM
Eddie long's Avatar
Eddie long Eddie long is offline
Advanced Member
Depends what you call fast dice , mine will last prob 10/12 hour when i'm messing around , and at the moment my battery seem to preform to the same ish output per charge but its maybe only 4-6 months old i think
__________________
Life isn't always a bowl of cherry's.
Sometimes it's HARD WORK
  #3
Old 13-07-18, 07:07 PM
Dicehunter's Avatar
Resident Newb
interesting thanks for the info Eddie
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
