Go Back   OC3D Forums > [OC3D] Graphics & Displays > Overclocking
Thread Tools Display Modes
  #11
Old 12-07-18, 10:02 AM
Warchild Warchild is offline
OC3D Elite
Originally Posted by FTLN View Post
Down to 1.25v (llc 6 stops the vdroop and no overvolts) for 5ghz
Cinebench stable, OCCT linopack with AVX Stable, Firestike physics test stable
Max cpu temp 59c ambient is around 23c ,vrm are around 59c under full load
Now that is a good sweet spot imo. Damn nice job!
  #12
Old 12-07-18, 10:06 AM
FTLN FTLN is offline
OC3D Elite
I think I should be able to get stable at 1.21 because the test above also passed with LLC 4 with gave me vdroop to 1.21v. I'll give it another go after lunch with vcore @ 1.21 and llc6
***Edit***
5GHZ 1.2v AVX Stable for OCCT, Cinebench, 3dmark Firestrike physics, gonna try some games and see if I get any crashes.
__________________
Intel Core i9 9900kK @ 5.00GHz @1.275v - Asus ROG Maximus Hero - Corsair 3000mhz CL16 LED 4x16GB SKHYNIX - Thermal Take View Glass - PM961 1TB x 2 RAID0 - Nvidia GTX 1080 Ti - Corsair H110i - Corsair Commander Pro - Asus ROG Swift PG279Q 2560x1440P G-Sync 165Hz
  #13
Old 12-07-18, 04:55 PM
Davva2004's Avatar
Davva2004 Davva2004 is offline
OC3D Elite
You got a damn good chip there. Good work.
__________________
  #14
Old 12-07-18, 05:51 PM
OC3D Elite
UPDATE
No crashes on any games / Asus Realbench ok too but still cant run prime95 with small FFTS for more than 30 seconds. No bluescreen but workers stop with fatal error..
__________________
  #15
Old 12-07-18, 06:59 PM
OC3D Elite
are you using manual voltage or adaptive?
  #16
Old 12-07-18, 07:18 PM
OC3D Elite
Manual, for the moment. Adaptive I still need to dial in.
  #17
Old 12-07-18, 11:14 PM
OC3D Elite
Removed manual voltage and re-enabled intel speedstepping features with adaptive voltage negatif offset 0.075v which gets me to 0.62v when idle and up to 1.2v when under load, all seems stable for 5ghz. Lost a couple of degrees on Idle temps also, they are now hovering around 28-29c mark compared to manual voltage where idle temps were mid 30s.
Had another play with Prime95 small FFT's and it seems that I need 1.275v to be stable at 5ghz although I only left if for an hour. But there is absolutely no workload in my lifelike this so I'm just keeping it at 1.2v.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
