Go Back   OC3D Forums > [OC3D] Graphics & Displays > Overclocking
Thread Tools Display Modes
  #1
Old 10-07-18, 11:00 AM
FTLN FTLN is offline
OC3D Elite
ASUS ROG STRIX Z370-I + 8086K Delidded
Hello,
Here is some initial tests I have done on my 8086K Retail from Intel :
5 GHZ - Stable at 1.28v OCCT Linpack with AVX enabled
5.1 GHZ - Stable at 1.3v OCCT Linpack with AVX enabled
5.2 GHZ - Stable at 1.328v OCCT Linpack with AVX enabled
These chips are good overclockers, today the weather is a bit cooler in Paris, 24c ambient and the cpu hits 70c max.
The Z370-I (Bios 1002) from Asus is also working well with LLC @ 6 , CPU voltage is rock solid, no vdroop, no overvoltage.
Cooling is a H115i from Corsair in pull configuration fans at fixed 1200rpm.
Memory is 2 x 16gb GSkill Aegis 2133mhz 16-15-15-35 overclocked to 3000mhz 16-18-18-38
Sumitranandan Pant
__________________
Intel Core i9 9900kK @ 5.00GHz @1.275v - Asus ROG Maximus Hero - Corsair 3000mhz CL16 LED 4x16GB SKHYNIX - Thermal Take View Glass - PM961 1TB x 2 RAID0 - Nvidia GTX 1080 Ti - Corsair H110i - Corsair Commander Pro - Asus ROG Swift PG279Q 2560x1440P G-Sync 165Hz
  #2
Old 10-07-18, 12:25 PM
tolagarf's Avatar
tolagarf tolagarf is offline
OC3D Crew
Seem you gotten a golden sample there. My i7 7700K @ stock 1.15v still hits 75C, and that's even the same test without AVX. I'm so not liking this CPU these days
  #3
Old 10-07-18, 12:50 PM
OC3D Elite
Delid it, takes 5 minutes of your life and the overclocking headroom after is great.
__________________
  #4
Old 10-07-18, 03:02 PM
tolagarf's Avatar
OC3D Crew
I don't have the tools for it and I plan on upgrading to a 6 core soon, so not gonna bother with it
  #5
Old 11-07-18, 09:04 AM
OC3D Elite
Ok so after some more testing I am stable at 5.2ghz 1.328v OCCT with AVX but Prime95 is definitely not stable, I get stopped workers after a couple of seconds and heat is in the top 80s to low 90s. I have no issues with any other benchmarks just Prime95 with small fft's kicks the sh#* out of my CPU ...
Maybe the Corsair H115 AIO is not up to the task, and I don't have other options in my NZXT Manta case..
__________________
  #6
Old 12-07-18, 03:06 AM
AMD Enthusiast
If everything is stable but one thing and that thing is a synthetic benchmark your probably fine. If everything you do is stable and 99% of your synthetic benchmarks are stable I'd call it a success.
__________________
I am Iron Man.
  #7
Old 12-07-18, 07:47 AM
Warchild Warchild is offline
OC3D Elite
Do you plan on using this clock 24/7? seems like you have a golden sample for sure even as far as 8086k goes, but do you want to impact its OC stability with over 1.3v plugged through it so much?
I would rather settle for a 5Ghz with lower volts like what you achieved and have longevity. Besides do you even notice a difference between 5 and 5.2 or was it just for synthetic scores?
  #8
Old 12-07-18, 08:07 AM
OC3D Elite
Actually finding the lowest volts for 5ghz was next on my to do list..
Anybody know what the stock intel volts for cpu vccio and cpu system agent are ? Currently have them at 1.23v for VCCIO AND 1.17v for System Agent.
Also, i'm not sure how people are putting 1.4v through these chips unless they have some mega cooling setup, my H115i cannnot handle more than 1.35v on this chip.
__________________
  #9
Old 12-07-18, 08:09 AM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
According to 8Pack anything up to 1.425v is completely fine for 24/7 usage with decent cooling on the 8700K and considering the 8086 is just a highly binned 8700K I'd imagine the same would be true for it.
__________________
- Intel Core i9 9900K @ 5GHz - Asus ROG Max XI Hero -
- Corsair Vengeance Pro RGB 4x8GB @ 3600MHz -
- WD Black SN750 1TB - RTX 2080 Ti @ 2000/7500 -
- Windows 10 Pro 64 Bit Edition - Corsair 680X Black -
  #10
Old 12-07-18, 09:59 AM
OC3D Elite
Down to 1.25v (llc 6 stops the vdroop and no overvolts) for 5ghz
Cinebench stable, OCCT linopack with AVX Stable, Firestike physics test stable
Max cpu temp 59c ambient is around 23c ,vrm are around 59c under full load
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
