Go Back   OC3D Forums > [OC3D] Processors & Platforms > Overclocking
Thread Tools Display Modes
  #11
Old 29-06-18, 06:57 AM
AMD Enthusiast
Since it's Event 41 that means it's a power loss issue. So something is causing your system to shut down.
Check all cables to make sure they are snug, make sure graphics card is seated all the way, make sure ram is seated securely with both tabs closed.
After that I would just run memtest and also try running with one stick of memory and then trying the other on memtest.
__________________
I am Iron Man.
  #12
Old 29-06-18, 09:00 AM
RobM's Avatar
RobM RobM is offline
OC3D Elite
event logs are pretty much useless next time it happens make a note of the bug check code on the blue screen or you could read the dmp file that gets created with a crash.
__________________
ASUS Prime x370 Pro | Ryzen 5 1600 | Antec 240 AIO | Corsair Vengance RGB 3000 2 x 8Gb | Asus Strix RX 470 | Samsung Evo 120gb ssd | Seagate Baracuda 1tb storage | EVGA 500w | Phanteks Entho ProM Acrylic Window | Windows 10 and Linux Manjaro
  #13
Old 02-07-18, 09:51 AM
BigDaddyKong's Avatar
BigDaddyKong BigDaddyKong is offline
OC3D Elite
Be sure to check the sub timings on your memories SPD information. I noticed on my 1800X, there were two of the sub timings that were not correctly set even when using DOCP.
Once I manual set these, all my little ghosts in the shell went away.
__________________
AMD R7 1800X-Asus Crosshair VI Hero-16GB GSkill 3200mhz-Corsair HX850-H110i-MSI 1070-Coolermast H500-Windows 10 Pro-Dell U3011-Dell 2007FP
Tags
crashes, problem, ryzen
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
