Go Back   OC3D Forums > [OC3D] Off Topic > Off Topic Chat > Serious Discussion
Thread Tools Display Modes
  #11
Old 03-04-18, 08:18 AM
Avet's Avatar
Avet Avet is offline
OC3D Elite
Yes that is correct. Wisdom teeth are a different story all together, and require specialist treatment. That particular case of 90 degree orientation is far from normal. So i understand why you needed to sign a disclaimer, because it is hard to guarantee 100% success.
My point is that doctor referral should be standard before major interventions. Usually it is done only for more complicated procedures. Private practice doctors just want to charge you another procedure, and they give you few questions only. Dice's case sounds to me as a slightly complicated, because if infection, so i understand why his dentist wanted doctor's opinion.
Also an RTG scan is often requested so the dentist can see how is tooth implanted into a bone. Molars aren't normally in contact with nerve, but we are all slightly different.
  #12
Old 03-04-18, 05:20 PM
russler russler is offline
Member
Every dentist seems different nowadays when one of my teeth split I was passed from pillar to post, went private after the second infection, who instead of pulling managed to save the tooth the only thing I had to do was run a course of antibiotics first, no mention of doctors referral.
  #13
Old 03-04-18, 05:38 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
Well I consulted a private dentist only a 5 minute walk from my place and they said I should take my course of antibiotics until the massive swelling, Just like the guvs video a while ago, Goes down, Then they will do a root canal, Disinfect, Clean etc... and fill it with permanent stuff, Going to cost £300 in total which includes aftercare but worth every penny.
__________________
- Intel Core i9 9900K @ 5GHz - Asus ROG Max XI Hero -
- Corsair Vengeance Pro RGB 4x8GB @ 3600MHz -
- WD Black SN750 1TB - RTX 2080 Ti @ 2000/7500 -
- Windows 10 Pro 64 Bit Edition - Corsair 680X Black -
  #14
Old 03-04-18, 06:49 PM
Warchild Warchild is offline
OC3D Elite
300 is cheap cost me 1600 for wisdom tooth extraction
  #15
Old 03-04-18, 08:54 PM
Member
£300 is cheap man (for private) mine was 700 for the canal and 450 for the gold crown, like you said worth every penny, nothing worse than tooth pain.
  #16
Old 04-04-18, 04:39 AM
Avet's Avatar
OC3D Elite
It is good that they can save it. It will be a lot of work but worth.
  #17
Old 04-04-18, 07:02 AM
OC3D Elite
I think dental pain is one of the worst pains we go through in life. It can drive people to madness or far worse.
I count myself lucky I haven't had to endure the same issues many of you have.
  #18
Old 04-04-18, 12:10 PM
Dicehunter's Avatar
Resident Newb
One of the main reasons I have problems now is that when I lived and worked in Germany, The agency I was working for messed me around with paying me, Took them 8 weeks and in that time I had to survive on 1 apple per 2 days and water, I looked pretty close to Christian Bales "The Machinist" character which had long term health implications.
1 day I was sitting in my apartment and half of an incisor just fell out, No decay or anything, Pure white, It just fell out.
__________________
  #19
Old 04-04-18, 12:46 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
It is truly awful. I am a biter. Not grinding, but biting down hard. It's autism, apparently. Any way, eventually they break and then I bite more the more it hurts. In this pic I had 6 teeth removed. They immediately put in the denture, but I never wear it any way.
I actually like having teeth pulled now. Every time one gives me any crap I just have it pulled. That pain is unabating. Deffo among the worst tbh. I had another 5 pulled out on the next visit, and have had two others pulled since. All my wisdom teeth are gone too.
__________________
  #20
Old 04-04-18, 01:31 PM
OC3D Elite
How did you let them get that bad? teeth biting/grinding wears enamel away but that still shouldn't resort to having so many removed? Teeth are usually incredibly strong, unless you are gorging on high sugar substances as well? or when you say biting do you mean clamping down on things like Pen tops/plastic etc?
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
