Go Back   OC3D Forums > [OC3D] Hardware & Software > Software Section
Thread Tools Display Modes
  #11
Old 24-03-18, 03:08 AM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
If you have to use a freebie then Avast is probably still the way to go I have it on my phone it can be a bit of a pest with its notification but all in all doesn't really impact performance much
__________________
DRAGON'S MIST
NZXT Phantom 630 White=AMD Ryzen 1700X=MSI MPG X570 Gaming Pro Carbon WiFi=Intel Optane SSD 9 480GB PCIE=32gig 3200Mhz GSkill Flare X= MSI GTX1080 Seahawk X=NZXT Kraken X62=MSI Optix MPG341CQR=MSI GK80 Vigor=Corsair Force LS 960GB=Cougar 700M=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with Aer RGB fans and RBG strip=Pioneer BDR-209D=Windows 10 Pro=Thrustmaster T16000M HOTAS=Corsair MM800 RGB CE
  #12
Old 24-03-18, 03:14 AM
AMD Enthusiast
Ok thanks for the help guys
__________________
I am Iron Man.
  #13
tannji tannji is offline
Member
Avast in silent mode is pretty good, and Antivir wasn't bad either. Like others most of what I do other than gaming is on linux, Solus specifically. I do use Clam there, because while the linux partition isn't all that vulnerable, almost everyone I interact with is on windows, so I like to be certain that i am not a vector. After the new build is active as my main rig, I am going to play around with running Win10 in a VM within Solus, and run a fresh image every time I reboot. hard to get a more persistent and secure solution.
  #14
Old 24-03-18, 03:16 AM
AMD Enthusiast
Yeah I wish I had a spare PC for Linux but being in school and stuff everything is windows based so it's far to much work to get everything in order.
__________________
I am Iron Man.
  #15
Old 24-03-18, 08:34 AM
RobM's Avatar
RobM RobM is offline
OC3D Elite
dual boot mate
__________________
ASUS Prime x370 Pro | Ryzen 5 1600 | Antec 240 AIO | Corsair Vengance RGB 3000 2 x 8Gb | Asus Strix RX 470 | Samsung Evo 120gb ssd | Seagate Baracuda 1tb storage | EVGA 500w | Phanteks Entho ProM Acrylic Window | Windows 10 and Linux Manjaro
  #16
Old 24-03-18, 04:58 PM
AMD Enthusiast
To much work. I'd rather have a dedicated system
__________________
I am Iron Man.
  #17
Old 24-03-18, 05:18 PM
Avet's Avatar
Avet Avet is offline
OC3D Elite
Comodo? Interesting. I don't know anyone who's used that before
Would you consider it unobstructive for the average user? Like poop ads and etc? It can handle everything on its own in "silent" mode or something?
It is smart in "silent" mode, but i like when it asks me everything.
  #18
Old 14-01-19, 07:52 AM
Steven Brown Steven Brown is offline
Newbie
Hi Folks! if you are looking free Antivirus software for your PC or Laptop and you are using Windows OS operating system than I will suggest you use Windows Defender. I'm using for 2 years still I'm using it never got any issue about it and also working perfectly for me. You will get this antivirus software by default on windows 8 and 10.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
