Go Back   OC3D Forums > [OC3D] Processors & Platforms > Memory
Thread Tools Display Modes
  #1
Old 15-03-18, 08:02 PM
pbthrane pbthrane is offline
Newbie
Error55 "No memory installed" switching from 4GB to 16GB kit on AsusMaximusIVExtreme
I recently put an old build that had been lying in parts back together and installed it in a new tower with a new GPU. It is working well with a 4 GB Kingston RAM kit - plays PUBG, runs smoothly, but needs more RAM.
I therefore purchased a used 16 GB Kingston RAM kit. When I install it, I get error message 55: Memory not installed.
My question is: How can I get this RAM kit to work?
First, let me tell you the build as it was before I installed the new RAM. This works. I can install the old RAM blocks and boot the machine:
Motherboard: ASUS Maximus IV Extreme REV 3.0 (please note, not the Extreme-Z, the Extreme)
BIOS recently flashed to the most recent 3604
CPU: Intel Core i7 2600K @3.40 GHz
Cooled by Corsair Hydro Series H80 water cooler
GPU: MSI GTX 1060
SSD: Kingston A400 120GB 2.5'' SSD used for booting
OS: Win10 Pro x64
PSU: 850W Chieftec NTRO 85+
RAM: KHX1600C9AD3B1K2/4G - 2 sticks of 2 GB installed in slots DIMM_A2 and DIMM_B2. These are called HyperX blu
____________________________________________
The new RAM kit is KHX1600C9D3K4/16GX. 4 sticks of 4 GB. These are called HyperX Genesis.
When I install them, the motherboard reports Error 55.
I have of course tried to install them one at a time in each DIMM slot. And I have tried all combinations of pairs in DIMM_A1/DIMM_B1 or DIMM_A2/DIMM_B2 as well as all 4 sticks. I also trust that the sticks have been correctly installed every time I have tried.
Edit2: It is possible to boot the machine with one of the new 4 GB sticks in the farthest DIMM_B2 or DIMM_A2, but not in DIMM_B1. All 4 sticks work in this manner. It is with pairs of sticks that I get error 55.
I have also tried to press the BIOS reset button on the IO. No luck.
The motherboard works because the old RAM sticks run on it. I trust the seller who told me the new 16 GB sticks work. From studying forums on similar topics, I assume it may be one of 3 things:
1. RAM voltage settings in the BIOS - I am not proficient in setting this up and would need guidance
2. BIOS version. I have the newest 3604 - perhaps a downgrade is needed?
3. CPU seating - though I do not have reason to suspect this as the machine is working just fine with the old 4 GB sticks.
This should not bias your replies to suggest how I troubleshoot this, I am only trying to provide my level of insight for your full insight.
Edit: I asked the seller and was told these RAM were running with no issue on his X79A-GD45 motherboard when he took them out 2 weeks ago to ship them.
UPDATE: The issue is now solved. The problem was pins in the CPU socket had been bent due to overtightening of the CPU cooler. I straightened the pins and now everything runs.
Links for components to save you time:
Motherboard: https://www.asus.com/us/Motherboards...US_IV_EXTREME/
Old RAM, working: https://www.kingston.com/datasheets/...AD3B1K2_4G.pdf
New RAM, error 55: https://www.kingston.com/dataSheets/...9D3K4_16GX.pdf
CPU: https://ark.intel.com/products/52214...up-to-3_80-GHz
Tags
asus maximus iv extreme, error 55, kingston hyperx, memory, motherboard
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
