Go Back   OC3D Forums > [OC3D] Project Logs & Gallery > Desk & Work Area
Thread Tools Display Modes
  #11
Old 28-12-17, 07:53 AM
SPS SPS is offline
Moderator
Originally Posted by AlienALX View Post
Have you looked on FB marketplace? well worth a look IMO, even if you don't have an account (just set up a bogus one so you can get access).
No, never used it but will have a look.
  #12
Old 28-12-17, 08:08 AM
BonkersMental's Avatar
BonkersMental BonkersMental is offline
Advanced Member
i use and old solid Oak Dinning Table, 6FT x 3FT , that i got from a 2nd hand shop, solid as a rock and plenty of space. I only paid £10 as well. Just needed sanding down and re-varnishing- job done.
__________________
Steam ID http://steamcommunity.com/profiles/76561198076851533/
And God said to John "come forth and recieve everlasting life " ...... but John came fifth and won a toaster
  #13
Old 28-12-17, 08:52 AM
SPS SPS is offline
Moderator
Yeah only problem with these for me are they tend to be too thick around the border due to the frame. Can't clamp things on easy and my chair doesn't go that low so won't be able to get under it probably. Reason I'm after a desk desk is because they normally take up little volume besides the top.
__________________
  #14
Old 28-12-17, 07:13 PM
Warchild Warchild is offline
OC3D Elite
Originally Posted by SPS View Post
Yeah exactly. Looking for something 100 quid mark if possible. A kitchen unit top may still be doable but I'm not 100% sure I won't move the location of it in the future.
Make your own.
Spend most of the budget on an oak top, and just get cheap sturdy legs.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
