Go Back   OC3D Forums > [OC3D] Graphics & Displays > Overclocking
Thread Tools Display Modes
  #21
Old 19-12-17, 11:18 AM
Damien c Damien c is offline
OC3D Elite
What software are you using to stream with?
If I stream I use OBS and use the NVENC encoder set to 1920x1080 60FPS, with a 4500 bit rate and have no issues with performance on the games or stream.
If I was to use the CPU I would probably have issues with the frame rate etc, as OBS will use up to 100% of the CPU leaving nothing for the game.
  #22
Old 19-12-17, 01:51 PM
7UpDiet 7UpDiet is offline
Newbie
hello guys,
UpdatE: i managed to OC to 4.8 with 1.270V and stressing using prime95 was successful and lasted for 1 hour now i know thats not enough but after that i streamed for two hours and didn't crash so all of these are good signs and might ran longer tests.
temps reached 100c a few times during stress test but while gaming and streaming for two hours of high quality and 2k graphics in csgo it never reached anything above +85c
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
