Go Back   OC3D Forums > [OC3D] Customer Care Forums > NZXT Forum
Thread Tools Display Modes
  #1
Old 12-11-17, 02:39 PM
Gaspari Gaspari is offline
Newbie
NZXT H700i - Push-Pull configuration in top
Hi Guys,
I think i have decided that i want to buy the new h700i (black) for my new 8700K build.
Is there any one of you that have been doing a push pull configuration with the radiator mounted in the top?
I will use the h115i or the Kraken x62 which both are 280mm rads which fits in length.
I will not use the stock corsair or NZXT fans i already have other fans.
I will use:
2 x Noctua NF-A14 iPPC-2000 (PWM)
2 x Corsair ML140 Pro (PWM)
The depth on both fans is 25mm so i will add 50mm plus the radiator
H115i depth 26mm
Kraken X62 30mm
The motherboard i will use is the Asus ROG Maximus X Hero.
So what i'm actually asking is if it's possible to mount fans in the top area above the mounting brackets then the rad.. and then fans under the rad? Or can you just stack them.. because i can't see any measurements on this part and that's why i'm asking you.
Hope someone cant shed som light on this! Thanks in advance guys!
  #2
Old 12-11-17, 07:31 PM
Eddie long's Avatar
Eddie long Eddie long is offline
Advanced Member
I recently watched hardware canucks review on that case , putting fans above the bracket on that case , it looks like although it is possible , you may encounter issues due to lack of space above the top fans
__________________
Life isn't always a bowl of cherry's.
Sometimes it's HARD WORK
  #3
Old 13-11-17, 06:13 PM
Newbie
Yeah i saw that review to. Well hope someone tried on this forum that can shine a light on this subject!
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
